73 F700 vin decode
#31
Yeh i talked to the previous owner and he said the f600 cab was rusty and he put the f700 cab on it and put the original vin back on. So it is a f600 with a f700 cab. So if u could decode the f600 vin above id love it. SORRY for so trouble with all the post's. Good to have ppl like u out there helpin. THANX
#32
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
S00398 = 1973.
158" Wheelbase.
COLOR code blank.*
F660 = F600 4WD (gas), 21,700 lbs. GVWR
4B8: 4B = Black all Vinyl / 8 = 81A Standard Cab.
M = Clark model 285V 5 speed Direct / H = Transmatic (Allison) Automatic Transmission.
84J: 84 not listed, verify the AXLE code / J = Power Steering.
21,700 lbs. Gross Vehicle Weight Rating.
411250:
41 = Chicago IL Ford District Sales Office, where the original selling dealer ordered the truck from.
1250 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
* When there is no COLOR code stamped on the Warranty Plate, the vehicle was painted a non standard color by the original purchasers request.
When this occurs, the vehicle is a Domestic Special Order.
#33
#34
I was about to sign off when you asked me to decode another, I had already decoded one a yours and another members '69 F600.
My peepers were blurry after spending 8 straight hours on this addictive site, typing other jazz, so I misread the VIN's series code and model code.
And, my '73/79 heavy truck catalog is on scratchy microfihe slides, that would blur the eyes of an owl in a NY minute.
Plus, I had to refer to a quoted post of yours (post 26) to type all the info into my post that you left out of post 24. How you managed that, I haven't a clue.
#36
Consider, there are over 649,000 registered members of FTE and a gazillion different forums. There is 1 Ford partsman, retired or not, guess who.
It takes a lotta time to research/type all this jazz, and no one is paying me a penny to do it. Take advantage while you can, cuz nothing lasts forever.
#37
#38
Help reading a VIN
The VIN is F61ERH17195.
What I think I have is:
1970
Ford
391
dump
5 speed
F600
Trying to find tranmission for it. The cast number on the tranmission is 230790. I think it is a clark 282V
also if anyone know a place to find a maintenance manual it would be great too.
thank you for your time
1970
Ford
391
dump
5 speed
F600
#39
F61 = F600 (gas).
E = 361 2V FT engine (F = 391 4V).
R = San Jose CA Assembly Plant.
H17195 = 1970.
While 230795 may be a Clark ID number, you need to post the TRANS code from the Warranty Plate to ID it. In fact you should post all the codes from the Warranty Plate.
Try faxonautolit.com for a shop manual, but be aware that Ford issued a shop manual one year, then added supplement manuals to it until the next major change (which occurred in 1973).
Faxon will be aware, since he's a Ford 'nut.'
#40
BTW I tried the vehiclehistorylookup.com site and it crunched away on the VIN claiming it was finding everything, then they took my Visa number ($1) and no report came. Their online chat basically said our database doesn't go back before '81 - too bad but you still have a credit.
Thanks
#41
I'm trying to order brake parts from napaonline and want to be sure I get the right ones. This is a dump truck my brother picked up from a water district that I'm trying to convert to a grain truck. Any info from the VIN or advise on brakes (seems to loose fluid but no apparent leaks) would be appreciated. VIN F70EVT69057
No brake info is available from the VIN. There are four possible sizes of front brakes, six possible sizes of rear brakes. You will need to know the exact sizes before ordering parts.
Look on the drums for any numbers, post what they are. If Ford related, I can tell you what the front/rear brake sizes are.
F70 = F700 (gas).
E = 361 2V FT engine.
T69057 = 1974.
#42
Thanks Bill. I had no idea the brake options would be so complex. The truck is about 100 miles north of me in Idaho and I've got some young guys helping me. It may be that there is nothing worn out, but that it has just sat too long. Is this post relevant to this model?
Thanks again.
Bleeding Hydrovac brake systems
https://www.ford-trucks.com/forums/89...ke-system.html
Thanks again.
#45
F70 = F700 (gas).
H = 6.1L (370) 2V or 4V
GH1993 = 1980.
The Warranty Plate is located on the left door face below the latch. To get more info, post all the codes from it.
