73 F700 vin decode - Page 2 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F700 vin decode
Old 10-27-2011, 06:45 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
I have one too, if you don't mind: 1FDNK77N9FVA65799
Quote:
Originally Posted by kevinksu2005 View Post
I am looking at buying a truck and it is supposed to be a 1985 Ford F700.
I would like to know first if it is. Second what motor we're talking about. Third a little info for the shipping company. Approximate empty weight with a flat bed, top of cab height, width at front fenders.
Welcome to FTE
1FDNK77N9FVA65799
1FD = FoMoCo USA, Incomplete Vehicle.
N = Class 6 Gross Vehicle Weight Rating range: 19,500-26,000 lbs.
K77 = F700 with 4WD option and diesel engine.
N = Detroit model DDA 990N or 990T 8.2L (501 cid) V8 diesel engine.
9 = Check digit, FoMoCo use only.
F = 1985.
V = Kentucky Truck Assembly Plant.
A65799 = Numerical Sequence of Assembly (the trucks specific serial number).
There are too many variations to estimate the weight (I wouldn't have a clue, regardless). You'll have to take it to a truck scale.
Ford truck parts catalogs do not list cab/fender and et cetera specs. These can vary wildly from one truck to another considering the gazillion possible variations.
Old 10-27-2011, 10:21 PM
kevinksu2005 kevinksu2005 is offline
kevinksu2005 is starting off with a positive reputation.
Thank you
Thanks for the quick response. I'm probably going to go ahead and get it.
Old 01-25-2012, 11:06 PM
xrunner800 xrunner800 is offline
xrunner800 is starting off with a positive reputation.
I have an old F700 vin: F70EVGC7485. Call me crazy but would it even make since to put the motor in an 85 F150. I'm not sure what year it is but its been sitting a while. Not locked up but I have no other info on the truck. A vin decode would be appreciated. Thanks in advance for any help.
Old 01-26-2012, 09:05 AM
Quote:
Welcome to FTE
F70 = F700.
E = ?
GC7485 = ?
GC7485 decodes to 1980, but there is no E engine code for 1980.
E = If it has a gas engine with 5 valve cover bolt holes per side, it's a 361 FT engine that was not available after 1978.
Verify the serial number, because it cannot begin with GC / Or verify if the engine code is an E.
Old 04-17-2012, 08:23 PM
stacyh stacyh is offline
stacyh is starting off with a positive reputation.
vin decoder
hi i am new at this so i am not sure i am doing it right... we just bought a F700 truck and can not figure out the vin number. it is f708vcd9442. there were other numbers below it. wb=158 Color=W type/gvw=f703 Trans=M Axle=e2h. can you help me?
Old 04-21-2012, 07:31 AM
Quote:
Originally Posted by stacyh View Post
We just bought a F700 truck and cannot figure out the VIN: F708VCD9442 // Warranty Plate: W.B. 158 / Color W / Type/GVW F703 / Trans M / Axle E2H
Welcome to FTE
F70 = F700 (gas).
8 = 1978: This is a diesel engine code only, but your truck has a gas engine. Verify the code and is it an I-6 or a V8?
CD9442 = 1978.
158" Wheelbase.
W = Ember Metallic.
F703 = F700 (gas), 23,000 lbs. Gross Vehicle Weight Rating.
M = Clark model 285V 5 Speed Direct Manual Transmission.
E2H:
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.55 / 17,500 lb. Capacity.
H = Ford Front Axle / Tire Carrier w/Manual Steering w/Steer Ease / 12,000 lb. Capacity
Old 04-25-2012, 09:48 PM
littlejohnr73 littlejohnr73 is offline
littlejohnr73 is starting off with a positive reputation.
vin decoder
Would you mine decoding another Vin?
F60DCW88000
176
Model F600
Body 48
Trans A
Axle F3
16000
DSO 218236
Thanks
John
Old 04-26-2012, 11:45 AM
Quote:
Originally Posted by littlejohnr73 View Post
Would you mine decoding another VIN?
F60DCW88000 // 176 / COLOR code blank * / Model F600 / Body 4 8 / Trans A / Axle F3 / 16000 / DSO 218236
Sure, you betcha and Welcome to FTE
F60 = F600 2WD (gas).
D = 330 2V H/D FT engine.
C = Oakville, Ontario Canada Truck Assembly Plant.
W88000 = 1977.
176" Wheelbase.
COLOR code blank *
F600 2WD (gas), 16,000 lbs. GVWR
4 8: 4 = Black all Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lb. Rear Axle Capacity (1970 thru today 500 series and larger trucks: There should be a 3rd digit of the AXLE code related to the front axle).
16,000 lbs. Gross Vehicle Weight Rating.
218236:
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
8236 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
* When there is no COLOR code, the vehicle is painted a non standard color per the original purchasers request. When this occurres, the vehicle is a Domestic Special Order.
It was not uncommon for trucks that were ordered from the US to be assembled in Canada. Decoded another VIN/Warranty Plate yesterday for an F100: Ordered from Atlanta, assembed in Canada.
Same jazz applies today: Oakville assembles the Edge, Flex and the rebadged Lincoln versions.
Old 04-29-2012, 10:42 AM
RDKENWORTH RDKENWORTH is offline
RDKENWORTH is starting off with a positive reputation.
Hey im also lookin at a supposedly 1973 f700/ Would u mind decoding it for me and any specs u can about it. The vin is F66DVSOO398. THANX
Old 04-29-2012, 12:07 PM
xoloski's Avatar
xoloski xoloski is offline
xoloski is starting off with a positive reputation.
I want in on this too....
I have a 1973 F600 with a VIN of: F61DVR01191
also states WB 158
Color M
Model F614
Body 489
Trans 2
Axle F3M
GVW 22,000
DSO 75
Thanks in advance....
Steve
Old 04-29-2012, 12:58 PM
Quote:
Originally Posted by RDKENWORTH View Post
Hey im also lookin at a supposedly 1973 f700/ Would u mind decoding it for me and any specs u can about it. The vin is F66DVSOO398. WB-158 MODEL-F660 BODY-4B8 TRANS-MorH haed to tell AXLE-84J GVW-21700 DSO-411250 THANX
ok got the scoop now, it has a 1979 cab now, original vin is F70FVB10109 and wb-212 color-kt gvw- e28 trans-2 axle-e2m max gvw-24000 dso-460749. The original tag is
Old 04-29-2012, 01:04 PM
Hey im also lookin at a supposedly 1973 f700/ Would u mind decoding it for me and any specs u can about it. The vin is F66DVSOO398. WB-158 MODEL-F660 BODY-4B8 TRANS-MorH hard to tell AXLE-84J GVW-21700 DSO-411250 THANX
Ok got the scoop now, it has a 1979 cab now, original vin is F70FVB10109 and wb-212 color-KT gvw-E28 trans-2 axle-E2m max gvw-24000 dso-460749. Decode both please now im told its the f600 with f700 cab and tag on it is the original f600. SOORY for the mess.
  #28
Old 04-30-2012, 11:18 PM
Any help on decoding this please . thanx
  #29
Old 05-01-2012, 06:20 AM
Original vin is F70FVB10109 / W.B. 212 / Color-KT / gvw-E28 / Trans-2 / Axle-E2M / Max GVW-24000 / DSO-460749.
Compare the VIN on the Warranty Plate (located on the left door face below the latch) with the VIN on the registration to see if they match.
Peeps replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plate on the replaced door.
If the VIN's don't match, probably none of the following decodes are correct.
F70 = F700 (gas).
F = 391 4V FT engine.
B10109 = 1976.
212" Wheelbase.
KT: K = Bright Red / T = Candyapple Red.
Type GVW (MODEL) code omitted.
BODY E2B: E could be a red interior, but there is no E2, and the B should be an 8.
2 = Clark model 282V 5 Speed Direct.
F2M: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lb. Rear Axle Capacity // M = Ford 7,000 lb. Capacity Front Axle with P/S.
24,000 lbs. Gross Vehicle Weight Rating.
Year omitted.
460749:
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
0749 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
  #30
Old 05-01-2012, 06:27 AM
Quote:
Originally Posted by xoloski View Post
F61DVR01191 // WB 158 / Color M / Model F614 / Body 489 / Trans 2 / Axle F3M / GVW 22,000 / DSO 75
Previously decoded via P/M
F700 vin decode Low Key Large Truck 3 05-15-2016 04:20 PM
Vin decode mikeinmilton Large Truck 18 01-21-2016 07:30 PM
vin decoder seohwash Large Truck 2 06-24-2015 06:24 PM
purchasing a F700 vin decode help please canyoncat Large Truck 16 05-31-2014 03:07 PM
F-700 bronczilla Large Truck 8 03-18-2014 08:37 PM
Tags
1973, 700, 73, check, code, decode, decoder, decoding, f700, ford, number, ranchero, truck, vin, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
