door panel removal
Old 06-29-2010, 09:57 AM
FordLou's Avatar
FordLou
FordLou is offline
door panel removal
Hey guys,
Need to remove a pass side door panel off my '99 F150. Any tips, tricks, hidden screws I need to be aware of so I don't break anything. Those panels are pricey. Thanks for any help.
Lou
Old 06-29-2010, 10:59 AM
cixelsyd's Avatar
cixelsyd
cixelsyd is offline
Believe it's similar to my '97, real easy.
- Remove the door pillar covers, they are simply snap in pieces.
- Remove the door handle cover and remove the door handle bolt.
- Remove the Power Window/Lock console, again it's snap in, just push upwards on the outer edge. I simply fed mine through the opening in the panel, some prefer to remove all of the harnesses.
- Check the bottom of the panel to see if there are 2 screws (some models have, some don't), and remove if present.
- Remove the inner horizontal window trim.
- Push upwards on the panel to remove.
Lots of words, but it's pretty simple. The panels are held in place by "hooks" that clip into the door frame, just don't try to pull it straight outwards or downwards and you'll be fine.
Old 06-29-2010, 01:14 PM
FordLou's Avatar
FordLou
FordLou is offline
Thanks for the info. Mine was a little different than yours, though. There was a screw under the door pillar at the top corner of the door panel. The door handle cover needed to be pulled straight off on the front edge, then the back comes out if you move the cover in the forward direction. No inner horizontal window trim to remove. The whole panel just lifts upward and off. Three tabs at the bottom of the panel just drop right into the corresponding door holes when reinstalling as you mentioned.
Lou
billy13
1997-2006 Expedition & Navigator
12-14-2009 10:29 AM
jmelong
1997 - 2003 F150
04-30-2009 10:12 AM
dmcenery
2004 - 2008 F150
10-25-2008 09:52 AM
tutiii
1997 - 2003 F150
09-17-2007 09:41 AM
VandeBogart
1997 - 2003 F150
07-22-2007 11:13 PM
Quick Reply: door panel removal
