460 crank in 429 anyone ever done this?? - Ford Truck Enthusiasts Forums
Old 06-29-2010, 08:27 AM
christians63 christians63 is offline
christians63 is starting off with a positive reputation.
Ive been told that if you put a 460 crank in a 429 you will up the compression a little and of corse gain a few inches. Has anyone ever done this or know that it will really raise compression. Thanks
Christian
Old 06-29-2010, 12:42 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
you also have to change the pistons as the 429 and 460 pistons along with the crank are the only difference between a 429 and 460.
if you just swap cranks, the pistons will probably come out of the cylinders too far and casue major issues.
and since you are changing pistons, you can virtually get any compression ratio you want with new pistons.
rgds
Mike
Old 06-29-2010, 11:23 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
What year Block?
what casting # on block and heads??
Old 06-30-2010, 12:07 PM
71cc 71cc is offline
71cc is starting off with a positive reputation.
Quote:
Christian
You must change the pistons. The crank and pistons are the difference. You can keep the rods. It is possible the earlier year 429 will have a .020" shorter deck height than a later 460, and the increased volume of the longer stroke would have a very small impact on compression. But you have to buy pistons.. so pick out what you want. I did this when rebuilding a 70 model 429 just because it was easy. The only increased cost was finding another crankshaft. I would highly recommend balancing it when done.
wyoming4x4's Avatar
Some cranks will not fit the newer block?
On the crank without counter weights up front it will not fit certain blocks. the counter weights are thicker if I remember correctly. been awhile but ran into this once. You can grind the block and clearance it but its a lot of work. Or just check the fit with crank in block. Usually the older cranks like the pre 78 if I remember. I just remember it being a pain in the but. Cranks with counter weight up front have thinner counter wieghts and clearance isn't a issue on all blocks. Definetly check before committing to anything. hard lesson might save you some headaches. Older blocks haved shorter deck height also if I'm correct. My 460's been running good for a long time and haven't had to mess with this stuff in many yrs. The old 429 is sitting in shop on stand as spare just incase situation, good engine but wanted more. Catch you later any questions drop a message.
Fender Flares? christian.lewis 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-12-2015 07:18 PM
429 General Engine specs jesse1385 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 06-25-2005 10:18 PM
F-600 truck 370 cid engine question gabraham Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-16-2003 06:41 PM
461????? tbolt 460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 02-08-2003 06:06 AM
429 questions tatonka Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 02-06-2002 11:11 PM
Tags
429, 460, balancing, block, change, crank, crankshaft, fast, fit, ford, forum, make, pistons, replace, rods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
