Wiper wont shut off - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Wiper wont shut off
Old 06-29-2010, 03:40 AM
roachslayer roachslayer is offline
roachslayer is starting off with a positive reputation.
Wiper wont shut off
Looking for ideas please.
My wipers will simply will not turn off unless I turn the key off. Annoying!
Everything else about them is perfectly fine. They initially turn on only when I want them, they set to the speeds I want, etc. If I turn them OFF, they behave as though I set it on the slowest intermittent setting. I have to shut the key off and back on in order to make it stop. Madness!
I have checked fuses. I have tried swapping relays (at least one relay in the main box is for the wipers, so far as I can tell). All to no avail. If anyone has insight on what else to try or look for, that would be great. It really seems like a stuck relay issue to me... but I dont know where else to look. Or, what else could it be?
2001 Expedition EB 5.4L 4x4
Old 06-29-2010, 11:14 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
That sounds like the wiper delay module is acting up.
Old 06-29-2010, 04:07 PM
hmmmm. on this model, I believe the module/controller is in the whole turn signal wiper switch assembly itself (SW5548), needing the whole unit to be replaced. Not cheap. Dang.
Old 07-04-2010, 07:39 PM
RESOLVED
For anyone else that comes across this or a similar issue, here is more detail.
I checked/swapped all relays related to wipers with same type relays related to other things. No change. So I knew it had to be the wiper switch. Furthermore, when hooked up to a Ford specific OBD II scanner, indeed, it showed an issue for the Multifunction Switch.
Replaced the switch in the steering column using these steps:
Lost the turn signals, how to replace multifunction switch - Ford Expedition Forum
...resolved the issue. Cheapest I found was around $90 online. Dealer cost was around $130. Part Number for my rig: SW5548
Either way, its a stupid rip off and a stupid thing to have go bad that should in theory never go bad. After all, there is usually a cause and effect when parts go bad. Such as water leak causes short. But no... this part failed without cause. Awesome. Of course, there is no aftermarket part for something this specific, so I expcet another failure without cause at some point.
Weird: Hazard / Turn Signal / Heater & AC Control Issue cpye2 1999 to 2016 Super Duty 4 12-27-2013 01:16 PM
Wipers only work on low, won't shut off 1994 f150 4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 09-05-2013 02:55 PM
Wiper Motor Stays On Monzter Kuztomz 1999 to 2016 Super Duty 17 07-18-2011 11:18 AM
Wipers Not Working Properly mattd860 1987 - 1996 F150 & Larger F-Series Trucks 13 05-30-2009 06:21 AM
windshield wipers stay on rsuszek2 1987 - 1996 F150 & Larger F-Series Trucks 1 07-14-2006 11:24 PM
Tags
2000, 2003, 2006, expedition, explorer, ford, ranger, shut, taurus, turn, windshield, wiper, wipers, wippers, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
