messed up spark plug wire order - Ford Truck Enthusiasts Forums
Old 06-29-2010, 12:40 AM
kay2lkay kay2lkay is offline
kay2lkay is starting off with a positive reputation.
i knew i should have had a mechanic! ladies should not work on trucks now the spark plug wires out out of order for my 1971 ford f250 camper special anyone know the order to the plug wires or how can i find out
Old 06-29-2010, 12:48 AM
CHELLIE's Avatar
CHELLIE CHELLIE is offline
CHELLIE is gaining momentum as a positive member of FTE.
NONESENCE More ladies should work on Trucks
CHELLIE's Avatar
what size eng do you have ? is it the 360 v8
Old 06-29-2010, 12:53 AM
CHELLIE's Avatar
go to this post if its the 360 V8 or 390 V8 for the fireing order
http://www.ford-trucks.com/forums/58...n-a-360-a.html
help spark plug wires
390 can you help please
Old 06-29-2010, 12:57 AM
CHELLIE's Avatar
Quote:
the 360 and the 390 has the same fireing order, go to the post shown above #4
Sparx Macgyver's Avatar
Sparx Macgyver Sparx Macgyver is offline
Sparx Macgyver is starting off with a positive reputation.
Sorry if this is rudementary and crude, but I did my best to copy the order from my manual. It covers Ford Trucks '65 ~ '86.
This is the V8 firing order. If yours is different let me know. I have orders for both straight six and V6.
Old 06-29-2010, 12:58 AM
Ladies are definitaly welcome under my hood! There also welcome in my room too.
But ladies that can wrench are awesome..
Old 06-29-2010, 01:02 AM
CHELLIE's Avatar
Thank you for the complements towards ladies
Old 06-29-2010, 01:04 AM
Your welcome.
I encourage all ladies to get under there hood and do repairs themselves.
Old 06-29-2010, 01:09 AM
CHELLIE's Avatar
Kay on post #4 i left you a Diag that i found here on FTE , when replacing Spark plug wires, do 1 at a time, measure the new one with the old one for size, that way, you will never get lost with the fireing order, but then again, this is a great way to learn, and work your way out
Old 06-29-2010, 01:15 AM
Good advice Chellie. I didn't do that when I replaced the plugs and wires on an '82 Jeep Wagonner I had. great dependable 4X4 that was. Unfortunatly I had to figure out what was what with the wires because I didn't do them one at a time. I unhooked all of them.
So yeah, one at a time is definatly the way to go.
Old 06-29-2010, 01:18 AM
I should also mention I was young, and thought I knew everything. Plus it was my first time doing that kinda thing myself.
Old 06-29-2010, 01:37 AM
CHELLIE's Avatar
Kay, remove all the spark plug wires from the eng. and match them up, normally you will have a pair of small, med, long and longer wires 2 of each, now find #1 on the cap, its next to the clip that holds the cap on, mark it with some chalk or nail polish LOL
looking down at the cap, the fireing order goes in a counter clockwise rotation, it looks like a med wire will be used for #1 cyl. #1 is on the pass side front of the eng, put the wire in the #1 shown on the cap and #1 cyl, pass side front of eng. next is #5 it looks like a small wire, put that in the cap next in a counter clock wise rotation, then to #5 Cyl. thats on the driver side, front cyl of the eng.
Old 06-29-2010, 01:41 AM
CHELLIE's Avatar
to make the job a little easier, spray a little WD40 into the spark plug boot, it will slip in better. Are you ok now with the Info that has been posted Kay ?
352 firing order is correct but on different distributor locations asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-06-2016 01:36 PM
95 f150 5.0 spark plug replacement NotSoSporty98 1987 - 1996 F150 & Larger F-Series Trucks 12 02-23-2016 07:30 AM
Exhaust manifold smoking jesika baur Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 08-09-2015 11:54 AM
Dura Spark II Upgrade For FE Series Engine ScallyWaggler 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-16-2015 03:17 AM
spark plug wiring diagram 98 e150 marvel150 1968-2013 Full Size Vans 1 01-08-2011 06:06 PM
Tags
1971, 1999, 2000, 360, 96, cables, f150, f250, firing, ford, lightning, order, plug, put, spark, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
