Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-28-2010, 08:36 PM
motopsyko32's Avatar
motopsyko32 motopsyko32 is offline
2000 Ford Excursion
My Garage
motopsyko32 is starting off with a positive reputation.
where to find pneumatic couplers
I am looking for pneumatic couplers like these for a 1/2 inch air hose (for a train horn).
Where can i find these (preferably locally)?
Click the image to open in full size.
  #2 (permalink)
Old 06-29-2010, 05:28 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
I haven't had much luck find those locally. A couple of ideas would be high end computer stores, those fittings are used in water cooling processors. Maybe aquarium stores.
If you get in desperate need, you can use brass ferrule fittings. Ace hardware, lowes, home depot should have something that will work for you. You might look there anyway, say in the irrigation section.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 06-29-2010, 08:27 PM
2000 Ford Excursion
My Garage
Ace and Home Depot only had Shark Bites for copper tubing and pvc tubing. The guy said it would not work for irrigation hoses.
  #4 (permalink)
Old 06-30-2010, 02:16 AM
chiahunw chiahunw is offline
2004 Ford F-250
chiahunw is starting off with a positive reputation.
Try McMaster-Carr. LINK
__________________
2004 F250 PSD XLT Sports CC SB FX4
  #5 (permalink)
Old 08-16-2010, 12:34 AM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
1984 Ford F-150
Wyowanderer is gaining momentum as a positive member of FTE.
They are also available a heavy truck part houses; they are used in air brake assemblies and other pneumatic systems.Iget mine locally.
__________________
Frank
1984 Ford F150, 300-6, NP435, NP208.
The welfare of humanity is always the alibi of tyrants-Albert Camus
  #6 (permalink)
Old 02-11-2011, 08:45 PM
jessie's Avatar
jessie jessie is offline
2002 Ford F-350
jessie is starting off with a positive reputation.
McMaster Carr, Grainger, Festo
  #7 (permalink)
Old 02-12-2011, 09:26 AM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
2007 Ford F-350
rotun is gaining momentum as a positive member of FTE.rotun is gaining momentum as a positive member of FTE.
Truck parts place, like stated above, should have them for d.o.t. airbrake systems. Running d.o.t. tubing is a good idea as it is rated for service brakes at a wide range of temps.
__________________
2007 F-350 CC LB Harley Ed.
  #8 (permalink)
Old 02-23-2011, 05:34 PM
Zmann Zmann is offline
Garage is empty, add now
Zmann has a good reputation on FTE.Zmann has a good reputation on FTE.Zmann has a good reputation on FTE.
think about PEX fittings ? I don't know if they make what you pictured in 1/2 inch ?
but pex does and it has all kinds of fittings
  #9 (permalink)
Old 03-01-2011, 03:11 AM
Roadfind's Avatar
Roadfind Roadfind is offline
Roadfind is starting off with a positive reputation.
Fittings
Any truck shop/stop , and any Napa store . If you have a air ride supplier dealer in your area . Pretty commen air fitting .
__________________
ollllo
  #10 (permalink)
Old 03-01-2011, 08:16 AM
He's looking for 1/2 id those aren't common IMHO
  #11 (permalink)
Old 03-01-2011, 11:37 AM
Roadfind's Avatar
Fittings
Half inch air line is a common size , I have it in 1/8" - 1" line . They make air line in rubber and hard line that is made from PVC Synflex DOT approved line . The fittings are made in brass and plastic . I like to use brass over the push-pull plastic design . Most good auto parts supply houses carry have most sizes in stock .
__________________
ollllo
  #12 (permalink)
Old 03-01-2011, 11:55 AM
Good to know
Thanks
I have not seen the larger stuff
  #13 (permalink)
Old 03-01-2011, 07:12 PM
2000 Ford Excursion
My Garage
hornblasters.com
Tags
coupler, couplers, find, ford, forum, pneumatic, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
