Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-28-2010, 06:18 PM
EXPY2010 EXPY2010 is offline
Garage is empty, add now
EXPY2010 is starting off with a positive reputation.
2010 Headrests suck - need replacements
The 2010 driver/passenger headrests are bent forward way too much. I know they say its a safety factor for whiplash but it is terribly uncomfortable.
Why drive for years in discomfort for the chance you might get rear ended.
You cannot sit with a proper posture with these headrests, no exaggerating. My back is always hurting during and after driving.
Any headrests on the after market I can use or maybe the headrests of another yr EXPY?
Thanks!
  #2 (permalink)
Old 06-28-2010, 06:51 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
2007 are the least tilted.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 06-29-2010, 12:44 AM
Is there a site to buy them online?
  #4 (permalink)
Old 06-29-2010, 05:40 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
While you're looking recline the seat a couple of notches. If too upright the headrests smack you in the back of the head. These are still rods inserted in the seats I assume? Reforming the angle should work.
-- Chuck
  #5 (permalink)
Old 06-29-2010, 10:31 AM
berry1234's Avatar
Quote:
I would probably try to buy it at a local dealer. There is a small chance they have changed the design of the replacement 07 headrests to match the 2010's pitch. Also might be worth it to take one out and take it to an upholstery shop and see if they can bend it a bit or replace the bars.
__________________
  #6 (permalink)
Old 07-03-2010, 07:37 AM
blackout150's Avatar
blackout150 blackout150 is offline
2001 Ford F-150
blackout150 is starting off with a positive reputation.
I took mine out and put them in backwards. They were making my neck hurt and I had to recline the seat too far back to make the headrests comfortable.
__________________
2007 Edge SEL, Copper w/vista roof, FWD
2001 F150 XLT FLareside Ext Cab Oxford White 5.4 Auto 3.55L.S.
1971 Mustang Mach1 M-code, currently 302/AOD, restoration in process
  #7 (permalink)
Old 07-06-2010, 02:59 PM
rjd75 rjd75 is offline
rjd75 is new and has a neutral reputation at this point.
Here is the solution to the headrest problem..
Tools required
2 people
2 pieces of cardboard
one small piece of plywood
one 2ft length of square or round pipe just big enough to fit over headrest pole
Instructions
1. Remove headrests
2. place one piece of cardboard on the ground
4. place headrest on cardboard
5. cover head rest with second piece of card board
6. place plywood on top of headrest
7. have one person kneel on the plywood to hold the headrest in place
8. have the other person slide the pipe over the pole and bend it down about 1/2" or as desired
9. reinstall head rest and enjoy your 2010 expedition
  #8 (permalink)
Old 07-07-2010, 09:40 PM
johnkn johnkn is offline
johnkn is starting off with a positive reputation.
I have a feeling that your solution may change a bit when the 2011's come out with DVD screens built into the back of each headrest.
Probably need to then deconstruct them, bend the bars and reconstruct. That may then make the angle of the screen wrong. It's always something.......
  #9 (permalink)
Old 07-19-2010, 12:42 PM
Harleyrider206 Harleyrider206 is offline
Harleyrider206 is starting off with a positive reputation.
2010 Head Rest
Thanks to rjd75 easy fix to make the headrest comfortable.... safer then turning the headrest backwards ....Happy Trucking
  #10 (permalink)
Old 07-19-2010, 12:43 PM
2010 Head Rest
  #11 (permalink)
Old 02-12-2011, 10:47 PM
edycri edycri is offline
edycri is starting off with a positive reputation.
Just replace them with Navigator headrests.
  #12 (permalink)
Old 02-15-2011, 03:21 PM
berry1234's Avatar
Quote:
Why spend that much cash? Someone just offered a free solution.
__________________
  #13 (permalink)
Old 02-15-2011, 04:10 PM
You can get them for cheap just have to search around a little. If you want to take a chance in breaking one of the bars or both while trying to bend them then you should go with his solution.
  #14 (permalink)
Old 02-16-2011, 10:25 AM
Unless you are King Kong I say the changes of breaking them using this method are slim to none..
  #15 (permalink)
Old 02-16-2011, 10:41 AM
berry1234's Avatar
This is the strangest logic I have ever seen.
'why take a chance at breaking them' - why does this matter if you can get them for 'cheap'?
Why not attempt to fix what you have for free THEN if it breaks you buy them for 'cheap'.?
__________________
Tags
2010, expedition, explorer, f150, ford, headrest, headrests, monitors, rear, reinstalling, replacement, suck, tilted, truck, uncomfortable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
