Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vendor Specials, Discounts, Product Announcements & Group Buys
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
  #1 (permalink)
Old 06-28-2010, 03:29 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
Garage is empty, add now
1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.
2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel
Check here for current pricing...2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel Turbo
Our engine vacuum pumps motors are some of the highest quality replacements on the market!
This electric Air Vacuum Pump Motor for Ford diesel trucks is a new, aftermarket replacement motor. It is a direct replacement for the old electric vacuum pump motor. It produces extra vacuum that the diesel engines have trouble producing.
The original pump from Ford, after many years of use, tends to stop working. With the loss of this motor, all vacuum operated systems connected will stop working. This could include 4WD systems with vacuum operated hubs, heater, defroster, and A/C doors, emission devices, plus many more! If you are having problems with any of the above systems, it may mean that your electric vacuum pump is bad and this part could be eaxctly what you need.
This new electric vacuum pump motor has the following specifications:
Electrically powered with correct plug
Replaces dealer part numbers: 6C3Z2A451A, 6C3Z2A451BA, 4C3Z2A451BA, F81Z2A451BA, 6C3Z-2A451-A, 6C3Z-2A451-BA, 4C3Z-2A451-BA, F81Z-2A451-BA
Built to strict quality control standards
Limited lifetime warranty!
Fits the following diesel turbo engines:
V8-445ci 7.3L DIESEL Turbo Vin F
V8-363ci 6.0L DIESEL Turbo Vin P
If your check engine code is coming up with an electric vacuum pump problem, this could be due to a motor. Many pumps, due to the weather will corrode and freeze up on the inside, causing the pump assembly to malfunction. Replace your frozen or broken vacuum pump motor now with this great fitting, alternative.
This electric vacuum pump motor assembly makes a great replacement, and has good cost savings over a dealer vacuum pump assembly.
Backed by manufacturer's limited LIFETIME warranty.
For as long as the original purchaser owns the vehicle, in the event this pump should fail due to manufacturing defects, we will REPLACE the pump free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
FREE SHIPPING
Click the image to open in full size.
__________________
GREAT SELECTION OF TOW MIRRORS
Tony
1A Auto Parts
CALL ME DIRECT1-866-403-3393
Shop For: Ford Truck Parts
Tags
03, 2007, 6c3z2a451ba, codes, diesel, engines, f350, f81z2a451ba, ford, ford truck parts, ford vacuum pump, operation, pickup, pump, trucks, vaccum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
