dual master conversion review lesson needed
i purchased a dual master for an all drum '68 mustang. i plan to put in on my f-1 retaining my all drums. i have the engineered components, inc. pickup truck adapter plate to mount the mustang cylinder. since most of the postings are for disc/drum or disc/disc, i have a few questions re: drum/drum. do i need a 10 LB residual valve for front and another for the back line. can i use a "t" for the front line or do i need a "metering valve"? also the eci diagrams for disc set-ups show the line coming from the reservoir closest to the front (pushrod end) goes to the back brakes. is that what i do with mine? i can/will call eci if nec. but i want to learn what i can and i don't want to be buying hardware i don't need. thanks, dick r
The link oldf1 posted is a great reference. But in the photos, it shows a GM Corvette style master cylinder, and the hookups for front and rear brakes. On the Ford m/c, they are reversed, where the side closest to the pushrod is for the front brakes, and the one farther away is for the rear brakes.
Dick,
In the '67 Mustang drum/drum master, both reservoirs are the same size. Consequently, it matters not which one feeds the front brakes. Additionally, it will already have internal RPV's for both circuits. No additional external RPV's are needed and would likely cause more problems than anything if you installed them. Plumbing it up should be nearly identical to the stock setup except for each axle having its own circuit.
now we are getting somewhere, thanks to all. i have the napa36222 new mastercylinder. it looks like the one in old f1's pic. do i need to pull the flare out to see if there is a valve behind it? is that what the pick is for in the pic? don't want to damage it. glad i started this thread, we won't be putting it in until next fall, but i want to be prepared. one last question, do i need the metering valve? is that a stock item, i read somewhere, junkyard only. dick r.
The RPVs in master cylinders that were originally equipped with them are an integral part of the unit and would not have been categorically deleted during the remanufacturing process. They wouldn't sell it without them as the wheel cylinders would quickly start leaking. If your new master is for a drum/drum '67 Mustang and looks like the one in the pic, then it will have RPV's in it. There is no need to pull the flare seats out and go prodding around. I don't know where the idea came from that new master cylinders no longer have RPV's. That's simply not true. If the original application called for them, they're in there. Quit worrying so much and go put it on already! You'll be glad you made the change.
i'm convinced. will put it in as is with the separate front/back lines. i won't be doing it right away because i drive it every day. in late fall we will install ford 9", new brake flex hoses, wheel cyls and the new dual master. we'll have the box off for some rehab, holes in fenders patched and new running boards. can't sacrifice summer driving to do all that. thanks for the great advice. dick r.
65fordguy
33
05-03-2016 07:41 AM
1956in1956
10-02-2015 09:29 AM
Resurrected 56 F100
08-23-2015 07:49 AM
rc1099
09-03-2009 12:11 AM
angus
02-23-2003 05:04 PM
