Leaf Spring removal
Leaf Spring removal
Did quite a bit of searching on here but couldn't find any reference to the procedures for removing leaf springs from a F100. I am still waiting on my shop manuals to arrive, but in the mean time I thought I'd check here for the answer.
I have got the axle removed as well as all but the main leaf spring on each side. I pulled the lock pins for each side spring hangers and removed the grease fittings from the pins.
What is the best way to get the shackle pins out? I gave the thing a good shot of Mouse Milk to help free it up.
yea did some digging and cleaning and found the holes in the frame. Was able to drive the pins out using a flat set on my rivet gun, and a section of round bar.
Tried the same thing on the fwd pins of the rear springs, but those don't want to budge...going to have to let them soak for a while.
At least none of the leaves are broken so a little cleaning and painting is all they need.
While you have the springs apart and clean, go to a spring shop and buy some Durlin strips of the appropriate width (Ithink it is 1 3/4" wide for the fronts and 2" for the rears.and put these strips between each leaf when you assemble them. They will work so much better, almost like coil springs.
Yea that is my plan after i clean them up and give them a coat of rust preventative.
I'm getting ready to replace my rear spring bushings as well. Can someone list the step-by-step procedures for doing it? Pictures would be a great help.
Hopefully I don't have to remove the rear drive shaft and/or axle. I was hoping to put the rear end on jack stands and support the differential with a floor jack.
It's a 51 F1
Thanks
It's a 51 F1
Thanks
Schickel
11-24-2013 05:20 PM
trevor8283
04-23-2012 09:34 AM
l_buck
06-30-2011 03:14 PM
Rusty Bucket'
26
10-31-2008 03:29 AM
Goobzilla
03-09-2005 11:58 AM
