old gas
Old 06-28-2010, 11:30 AM
lucky_strike's Avatar
lucky_strike
lucky_strike is offline
old gas
so my truck (69 f100) was sitting for about a year before i bought it, so i think the gas it bad, ive been looking up on who to get it out and someone said that i could mix new gas with old gas? or should i try and siphon it out? is there any auto store that sells siphon kits?
Old 06-28-2010, 12:17 PM
jowilker's Avatar
jowilker
jowilker is offline
ls, Others might disagree, but I would add as much new gas in with the old as I could get in, & fire it up without hesitation. It's not gonna take long to drive it out.
If it was 3-5 years old I would think differently.
John
Old 06-28-2010, 01:07 PM
yellow truck's Avatar
yellow truck
yellow truck is offline
Depends, if the tank is more than half full you may consider siphoning it and putting it back in slowly. The closer to full, the more I would hesitate to use it as is.
Old 06-28-2010, 01:22 PM
lucky_strike
the main tank is about half full and the spare tank it emtpy i think
Old 06-28-2010, 05:41 PM
Mustangtoby2001's Avatar
Mustangtoby2001
Mustangtoby2001 is offline
I've found you can pull the fuel line off at the pump and put it in a can, then blow into the tank to get it "primed". Make sure your hose from the pump is as low as you can get it, and it will usually drain out (siphon). Only a year old shouldn't be to bad yet, but I'd still try to get most of it out if you can. If not fill it clear to the top and try it, once it's down to half fill it up again.
Old 06-29-2010, 10:50 PM
69F-250's Avatar
69F-250
69F-250 is offline
I just started my 69-F250, it had been sitting for seven years. The gas tank was almost empty so I just added Five gallons of fresh gas with some Sea Foam additive. Checked the points and the plugs all looked good., primed it and started right up. I did add a new inline fuel filter to catch any junk from the tank.
Old 06-30-2010, 12:20 PM
dynamic's Avatar
dynamic
dynamic is offline
I usually mix in as much new fuel as possible...Sometimes I might even buy a couple gallons of premium to bring the octane up.
Old 06-30-2010, 12:38 PM
lucky_strike
i just might try that, ive started it and it runs fine, i just didnt know if it would ruin my engine or anything.
Old 06-30-2010, 04:33 PM
jowilker's Avatar
jowilker
jowilker is offline
The year old gas, is a little stale but is not bad gas. I bet you can drive the truck as is with no harm at all.
There have been times when I wasn't driving my truck much and the gas would be a year old. It would have been cranked and driven some but not enough to use up the gas.
John
Old 06-30-2010, 07:10 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
drive it.it's a ford
Old 07-01-2010, 10:52 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
I would say the opposite...the closer to full it is, the more likely that it's still good as a larger volume of gas deteriorates more slowly. I wouldn't worry about using gas that's only a year old in one of these old trucks, even with the crap they sell us that poses for gas out here in Ca.
Old 07-02-2010, 07:10 PM
sandmanf250
where i am in upstate n.y. i can still buy ethenol free gas. see if you can find some where you are ,add some carb cleaner and drive it.
Bohemian
Modular V10 (6.8l)
15
10-20-2020 07:26 PM
lameousername
09-06-2015 04:17 PM
79F-350
01-12-2011 01:00 AM
sbyers
1999 to 2016 Super Duty
21
08-12-2010 12:10 PM
axp117crow
04-22-2007 09:02 AM
Quick Reply: old gas
