'98 Expedition no forward gears, only reverse - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 06-28-2010, 01:14 AM
RR515 RR515 is offline
RR515 is starting off with a positive reputation.
Question '98 Expedition no forward gears, only reverse
My '98 Ford Exp (5.4L) won't go forward, only in reverse. Just happened at the end of today while parking my trailer. Note: 1) I had just switched to 4wd in a gravel, slope area and (2) when I went back out later to fiddle with this problem, I can only go slow forward at very high rpm (should be spinning tires at this rpm). Very bummed and looking for some answers. I appreciate any help!!!
Old 06-28-2010, 02:31 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
If the fluid level is okay, then I'd say it's tranny shop time.
Old 06-28-2010, 11:55 AM
Fluid is great. The problem occured just after switching to 4wd, so I was wondering if it could be an electrical short somewhere, like now its "stuck" in nuetral, not recognizing forward drive options. The dash shows AWD and 4WD options when I select them, but no forward motion. Is there a manual way to at least get it back to 2wd (with actual forward motion)???
Old 06-28-2010, 01:16 PM
The tranny determines forward and reverse, while the transfer case determines the 2H, 4H, and 4L options. Since you can get it to move in reverse, then the transfer case is transferring power from the tranny to the wheels; the transfer case is not the issue, the tranny is. However, if you insist on trying, the only way to manually shift to 2H is to remove the shift motor from the back of the transfer case and move the mechanism by hand.
Old 06-29-2010, 12:47 AM
Many thanks alloro. I have a reputable shade tree mechanic coming out Wed morn...I'm sure he'll think come to your same tranny conclusion.
(The shift motor went out almost 2-years ago and wasn't cheap to replace. If the shift motor isn't functional, wondering if it could also render the car's forward gears useless?)
4r70w no forward gears, only reverse. help needed.. rpm9001 Clutch, Transmission, Differential, Axle & Transfer Case 32 09-02-2016 12:19 PM
98 f150 have no forward gears achess3 1997 - 2003 F150 1 05-25-2015 07:49 PM
4r70w Transmission problem...ideas? KJRevord92 1997 - 2003 F150 4 02-07-2013 08:31 AM
98 5.4 stalls at sudden stop and going into reverse MikeD1980 Modular V8 (4.6L, 5.4L) 0 01-23-2011 10:03 PM
will a bad transfer case affect reverse bobwhyte2002 Ranger & B-Series 3 02-24-2009 06:21 AM
Tags
2000, 98, expedition, explorer, f250, ford, forward, foward, gears, lincoln, mountaineer, navigator, reverse, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
