5-speed swap? - Page 4 - Ford Truck Enthusiasts Forums
5-speed swap?
  #46
Old 07-30-2014, 02:00 PM
psycho monkey psycho monkey is offline
psycho monkey is starting off with a positive reputation.
hey redman84 i have been searching the internet for a 5 speed swap info thread and yours is by far the best. I am very mechanically inclined but i have never swaped a auto for a manuel yet and i was reading and it helps alot but i have some questions. i was wondering what all should i get from a doner truck and what all should i get new i dont have a place to put a doner truck i am staying in a rv park in san leon texas which is by texas city. So i would have to go to the junk yard to get my doner parts. Maybe you can help me out as i need it. I found a tranny from the junk yard here that they say works for 450 but you said your friend also gave you yours in college station how much did he charge and what all does he do to it does it come rebuilt or what. thanks man hope we can help eachother out my truck is a 96 ford f350 7.3 powerstroke and it has a 4 door cab so does that mean i need to yank the drive shaft of a nother vehicle what is also is the same size cab and bed?
  #47
Old 07-30-2014, 02:45 PM
FI460's Avatar
FI460 FI460 is online now
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
You'll need driveshafts from the correct cab/trans truck, or you'll need to have yours modified.
For the swap you'll need:
Trans
clutch/flywheel
Cross member
manual pedal assembly
trans hump (or cut a hole in the auto hump for the shifter)
Manual T-case shift bracket
I feel like I'm forgetting something, but that's all I can think of right now. The only new parts I used for my swap was a clutch and flywheel.
  #48
Old 07-30-2014, 03:05 PM
cool thanks man do you know what electrical i will have to endever??? also do you know if a 92 7.3 idi will work for a doner or does it need to be a powerstroke
  #49
Old 07-31-2014, 12:24 AM
FI460's Avatar
The trans will work.
I dont think the pedals work.
I dont think the driveshafts would work.
Shifter and t-case shifter should work.
I'll try and dig up the wiring when I get some time. Or, you could search for Rebilld's write up. I know it's there. I think the 4&5 pin will need to be moved to 14&15 in the trans harness, and something needs soldered for the cruise to work.
  #50
Old 07-31-2014, 01:02 PM
cool i will continue looking things up any tips just pass them ons thanks guys
  #51
Old 05-31-2016, 07:28 PM
Lopro2012 Lopro2012 is offline
Lopro2012 is starting off with a positive reputation.
Pcm swap
Well A zf5 PCM work in an automatic
  #52
Old 09-05-2016, 07:04 PM
Jumpmaster54 Jumpmaster54 is offline
Jumpmaster54 is starting off with a positive reputation.
Help please
I put my 1995 7.3 crew cab 4x4 with e4od into a 1996 manual crew cab 4x4. I cannot get the throttle response to happen. It runs. And idles fine. I used the auto pcm etc. The engine harness is still the 1995 auto. I am sure there a reason a few wiring differences like the 5 volt reference wire. Pin 90 and 91? What do I need to do. It is really gotten me to beer 30 many nights. I also want my cruise control to work.
86 f250 tranny swap Jmac947 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-09-2017 07:30 AM
ZF S5-42 Swap confusion PRIMERED79 SHORT BED 1987 - 1996 F150 & Larger F-Series Trucks 54 03-20-2016 06:16 PM
5-speed manual trans swap martinb 1973 - 1979 F-100 & Larger F-Series Trucks 24 11-15-2015 02:36 AM
'95 F-250 4.9L to 351/460 swap jerryparks Engine Swaps 3 06-10-2015 09:17 PM
49 body swap on 90 idi Alexbernard623 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 05-11-2015 09:03 PM
Tags
547, 97, bad, conversion, crossmember, ford, good, powerstroke, putting, speed, speeds, start, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
