5-speed swap? - Page 3 - Ford Truck Enthusiasts Forums
5-speed swap?
  #31
Old 06-30-2010, 12:20 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Quote:
Originally Posted by DZL JIM View Post
One other question came to mind.
Will the E4OD bolts work in the ZF, to bolt to the engine?
Sure will man.
Quote:
Originally Posted by Brown Falcon
I can't wait to have a 5-speed in my truck...
Yeah buddy! It is pretty sweet having it in mine. I wish my final drive gear wasn't quite as low but still have no complaints. I think a ZF 6 speed would be so cool in an obs as well.
  #32
Old 06-30-2010, 02:05 PM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
Quote:
Originally Posted by redman84 View Post
...I think a ZF 6 speed would be so cool in an obs as well.
I know a few that have gone through all the work and would have loved to do that as well. But I just don't have the time to mess with all that's involved, much less dropping that kind of $$$ on all the late model parts needed.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
  #33
Old 06-30-2010, 03:57 PM
redman84's Avatar
I feel ya man. I wanted one too but you see what I ultimately ended with. Oh well, I'm still stoked...
  #34
Old 06-30-2010, 08:12 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
All you would gain from a ZF6 is a granny low 1st gear. Final drive gear is almost identical.
  #35
Old 07-12-2010, 01:03 PM
DZL JIM's Avatar
PREMIUM SPONSOR
Another question on this.
Will the 4x4 shifter parts from the auto bolt right up to the ZF5?
__________________
DZLJIM.com
  #36
Old 07-12-2010, 01:39 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Quote:
Yahtzee. The way I see it the 5speed is better... less gear banging. Not a big deal on the highway, but to me driving a 6 speed in town is a bit of a PITA.
  #37
Old 07-12-2010, 05:44 PM
Quote:
Basically same as teh 5 speed. Just start off in 2nd gear with the 6 speed cause the granny 1st gear is useless without a heavy load behind you.
  #38
Old 07-12-2010, 06:37 PM
The few that I have driven were cranky about taking off in 2nd. I grew up using 1st as a granny gear in everything I drove, threw me for a loop when I had to actually use 1st
  #39
Old 07-12-2010, 08:17 PM
crazy4wdracer crazy4wdracer is offline
crazy4wdracer is starting off with a positive reputation.
I have only driven one 6 speed which is my dad's cummins. If you let the clutch slow it will take off in 4th without stalling. Every manual trans diesel that I have seen makes that grinding/lugging noise when using 2nd or higher starting off but I don't think that hurts anything. In my 5 speed OBS I can start off in 2nd with no problem even with my DMF going out. I have never driven a ZF-6 before though. I still like the spaced out gears in a 5 speed because it's almost impossible to not get it in the right gear.
  #40
Old 07-13-2010, 02:21 PM
884x4broncoII 884x4broncoII is offline
884x4broncoII is starting off with a positive reputation.
iv thought about the zf6 the gears in my zf-5 are too far apart for my liking, you can always skip gears when running empty
there is several times i wish i had a 3rd and a half gear second and a half would be nice occasionally as well. 5th to 4th drop is about right but once in 4th you got to wait till about 2k rpms and 45mph to downshift to 3rd where you jump up to almost 3k. 2nd-3rd gear has almost a 1k rpm difference witch can be a bit annoying when starting out on a really steep hill with a load
  #41
Old 07-13-2010, 02:27 PM
You could split gears if you put in a Gear Vendors unit...
  #42
Old 07-13-2010, 02:34 PM
it would be nice to find a 2 speed rear end that would fit my truck but the likelihood of that is probably pretty rare. a gear vendor unit would be nice but them suckers get spendy as well.
  #43
Old 07-15-2014, 08:45 PM
rgarcia1104's Avatar
rgarcia1104 rgarcia1104 is offline
rgarcia1104 is starting off with a positive reputation.
Redman84 Reading through this old fte post you mention somebody in Bryan tx to do an obs auto to manual swap is the guy still in biz? I need to get mine done
  #44
Old 07-16-2014, 09:32 PM
redman84's Avatar
Quote:
I don't know whether or not he would do that swap for you. I only a got a trans from there. Either way, really pleasant doing business w them. J&S Standard transmissions. Maybe j&p. they changed the name and can't remember which is the new name. Ask for James.
  #45
Old 07-19-2014, 09:27 AM
Thanx on the info I'm calling them I need some work done,i try to use shops that have good reputation here on fte
86 f250 tranny swap Jmac947 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-09-2017 07:30 AM
ZF S5-42 Swap confusion PRIMERED79 SHORT BED 1987 - 1996 F150 & Larger F-Series Trucks 54 03-20-2016 06:16 PM
5-speed manual trans swap martinb 1973 - 1979 F-100 & Larger F-Series Trucks 24 11-15-2015 02:36 AM
'95 F-250 4.9L to 351/460 swap jerryparks Engine Swaps 3 06-10-2015 09:17 PM
49 body swap on 90 idi Alexbernard623 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 05-11-2015 09:03 PM
Tags
547, 97, bad, conversion, crossmember, ford, good, powerstroke, putting, speed, speeds, start, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
