5-speed swap? - Page 2 - Ford Truck Enthusiasts Forums
5-speed swap?
Old 06-28-2010, 10:32 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Quote:
Originally Posted by helifixer View Post
different tail shafts on 2wd and 4wd, the trans would have to be split and change the shaft
x2. Can be done but best to get the correct one.
Quote:
Originally Posted by crash1
i did the swap and what learned and did was used f-150 5 speed cross member and a 1990 zf5speed. What i found is the gas 5 speed has starter mounts,the powerstroke has no starter mounts,and thats what the spacer is for because the zf for a powerstroke dose not have any.But all the rest is true its a bolt in and go.
Sweet. Was that crossmember different than your stock one then for the auto or did it end up being the same? So you're saying that if the spacer was not there then the starter would have nowhere to bolt up on?
Old 06-28-2010, 10:35 PM
redman84's Avatar
Quote:
Originally Posted by crazy4wdracer View Post
Not trying to hijack this thread but I just need a quick question answered.
My truck is a 97 2WD S-5-47. My transmission grinds pretty bad which is to be expected for the original tranny with 274K on it. I was looking for used transmissions and found a S-5-42 from a 95 7.3 4WD, it was rebuilt 10K ago. Will a 4x4 transmission fit in my truck?
Thanks guys!
Did you make sure that your pedal box bushings are good? I mean it does have 274K on it but if those plastic bushings are bad then you may save some money and get some more life from it.
Old 06-28-2010, 10:46 PM
crash1's Avatar
crash1 crash1 is offline
crash1 is gaining momentum as a positive member of FTE.crash1 is gaining momentum as a positive member of FTE.
The cross member between stick ans auto are different.You need a stick cross member.And yes on the spacer,the diesels need them for the starter mounting spot.
Old 06-28-2010, 11:05 PM
Krisx125's Avatar
Krisx125 Krisx125 is offline
Krisx125 is gaining momentum as a positive member of FTE.
Well............back to the start. Not going to do the swap. Prob gonna rebuild the auto. I dont have the help to do the swap.
Old 06-28-2010, 11:10 PM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
Jacob,
Not arguing at all.
This is all great info, just conflicting it seems, between what I have been told and what you guys that have done it have found.
Upon further inspection it indeed looks as if the alum spacer is needed for the starter which would make the ZF longer.
That will really suck if I have to have my shafts modded, which looks to be the case.
Cross member: I have no idea. I'll make mine work if it's at all possible.
I'll be sure to add my findings as well.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 06-28-2010, 11:42 PM
crash1's Avatar
it really isnt to hard like we said its direct bolt in if you have all the parts like a donor truck.If not you just gather them all up,and its easier to pull the auto and put in the stick then pull the auto and take in and get fixed the re install it,unless you just have a shop do it all.
Old 06-28-2010, 11:58 PM
Krisx125's Avatar
ok ok, everyone around here wants stupid money for donor trucks. So ill gather all the parts up. I have a massive shop with a lift so its not that bad. Except i sold my car so im down to one vehicle haha
Old 06-29-2010, 06:54 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Makes me glad I have the whole '88 F350 Crew Cab ZF 4x4 for my swap. I can use the driveshafts and crossmember from the donor truck.
Bad thing is the P.O. took out the Dana 60 front and put in a D50. I can still use the front springs and shackles, etc. for my 4x4 swap when I get to it though. Gonna just do the trans and t-case first.
Old 06-29-2010, 08:17 AM
crazy4wdracer crazy4wdracer is offline
crazy4wdracer is starting off with a positive reputation.
I changed the pedal box bushings and the ebay tie rod thing, it helped but I still want a new tranny because I can't get my truck into 2nd gear unless I'm at a complete stop.
I have 2 more questions: Is the tail shaft from a S-5-42 the same as the S-5-47? Is the tailshaft hard to change. I think this would be worth changing if I could get this used trans cheap enough. While I'm changing my trans I'm going to go with a Valair clutch and SMF. My clutch only has 35K on it but my DMF is is about shot.
Old 06-29-2010, 10:07 AM
redman84's Avatar
Quote:
Originally Posted by DZL JIM
...Cross member: I have no idea. I'll make mine work if it's at all possible...
I bet it wouldn't be too hard to use it. Just a little drilling of some new holes and bam. Hell there may already be some, I just didn't look since I had the other one. And you can use the same spacer that's in front of your E4OD as well. Same shape, same bolt pattern.
Quote:
Keep looking for that donor if its what you want. I almost gave up when one came up for a screamin good deal and boy did it make it stupid easy. Did it in my driveway, me and a bud. It may be expensive up front but I guarantee there are ten guys on here who will claim the IDM, PCM, injectors, harnesses, stuff from your auto setup, etc. Much less interior, mirrors, bumpers, seats.
I asked my tranny guy about the tailhousings from 42 vs 47. He said they are interchangeable. Now, I asked him about 4x4 to 4x4. I do not know if you can swap one from 2wd over. I bet you could though but don't bank on that. Someone else may know for sure.
Was it easy to change the pedal box bushings?
Old 06-29-2010, 11:54 AM
I kinda cheated and was lucky. The only bushing that was bad was the easiest one to get to (the one closest to the passenger side). That one just slides in and out without removal of the whole pedal assembly.
Old 06-29-2010, 02:03 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
I mean it does have 274K on it...
Cool one, Redman. :)
Here's a picture to go with what Redman's talking about...
From a 188k '90 f250 351w, clutch-master-cylinder pushrod and the
stud that "sorta ;)" moved it...
http://www.panix.com/~alvinj/file12/pushrods.jpg
...and the new brake-pushrod that I replaced the wornout one with
but that took welding in a new larger-diameter stud and shortening
the brake pushrod too....
http://www.panix.com/~alvinj/file12/pushrod.jpg
That's what "don't fix it if it ain't broke" looks like to a tinkering fool
and "born to modify" guy like me. ;)
Alvin in AZ
  #28
Old 06-30-2010, 05:27 AM
DZL JIM's Avatar
PREMIUM SPONSOR
One other question came to mind.
Will the E4OD bolts work in the ZF, to bolt to the engine?
__________________
DZLJIM.com
  #29
Old 06-30-2010, 05:55 AM
crash1's Avatar
Yes they will
  #30
Old 06-30-2010, 06:02 AM
I can't wait to have a 5-speed in my truck...
86 f250 tranny swap Jmac947 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-09-2017 07:30 AM
ZF S5-42 Swap confusion PRIMERED79 SHORT BED 1987 - 1996 F150 & Larger F-Series Trucks 54 03-20-2016 06:16 PM
5-speed manual trans swap martinb 1973 - 1979 F-100 & Larger F-Series Trucks 24 11-15-2015 02:36 AM
'95 F-250 4.9L to 351/460 swap jerryparks Engine Swaps 3 06-10-2015 09:17 PM
49 body swap on 90 idi Alexbernard623 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 05-11-2015 09:03 PM
Tags
547, 97, bad, conversion, crossmember, ford, good, powerstroke, putting, speed, speeds, start, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
