460 crank bearings size help
I was given a crank/engine from a 73 460 car (2yABC) that the previous owners says was turned. I assumed .10 over but after installing new crank bearings there was at least another .10 gap in there between the crank and rod bearing. The pistons from the same engine are .30 over so my next assumption is that the crank is .30 over. To be safe I was going to use a micrometer and measure the diameter of the crank and subtract that number from what the crank was brand new. So, two questions: What was the size of the crank from the factory and am I on the right track?
Thanks
Thanks
Thanks for the reply. And thanks for not goofing on me for a stupid question. So when I order new bearings I would order then say .010 undersized?
stock specs in my book are crank journal 2.9994-3.0002 rod journals 2.4992-2.5000.
find out what yours are, then base what size bearings you need from that.
JPMallory
27
06-09-2017 01:01 PM
mogyver69
2004 - 2008 F150
06-02-2017 12:55 AM
ramsay
04-09-2016 08:05 PM
boond0cksaint
17
09-28-2004 08:25 PM
370, 460, bearings, crank, crankshaft, dimensions, ford, journal, journals, main, rod, size, specification, specs, stock
