460 crank bearings size help - Ford Truck Enthusiasts Forums
Old 06-27-2010, 08:04 PM
KeeterBob KeeterBob is offline
KeeterBob is starting off with a positive reputation.
I was given a crank/engine from a 73 460 car (2yABC) that the previous owners says was turned. I assumed .10 over but after installing new crank bearings there was at least another .10 gap in there between the crank and rod bearing. The pistons from the same engine are .30 over so my next assumption is that the crank is .30 over. To be safe I was going to use a micrometer and measure the diameter of the crank and subtract that number from what the crank was brand new. So, two questions: What was the size of the crank from the factory and am I on the right track?
Thanks
Old 06-27-2010, 10:39 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
When a crank is turned it is then undersized. You need to get your decimal points in the right place, but I /we know what you mean and yes, get a good set of mics that read in .0001" so you can determine how far it was turned before buying bearings.
Old 06-28-2010, 06:35 PM
Quote:
Thanks for the reply. And thanks for not goofing on me for a stupid question. So when I order new bearings I would order then say .010 undersized?
Old 06-29-2010, 07:19 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Quote:
No you should find out what the crank is and THEN order bearings.
stock specs in my book are crank journal 2.9994-3.0002 rod journals 2.4992-2.5000.
find out what yours are, then base what size bearings you need from that.
Old 06-29-2010, 09:04 AM
mark a.'s Avatar
Crank is undersize, bearings are oversize.
Old 07-03-2010, 07:05 PM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
My 2 cents are, make sure the mic is set right using a "standard"...they are many times out of wack and worthless...also check the journals in a few readings, rods too for roundness, theres not a lot to play with before reaching put out of service status
Hard starting after sitting a few days. JPMallory 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 08-01-2016 08:33 PM
Long crank start and no oil pressure when warm ramsay 6.0L Power Stroke Diesel 6 04-09-2016 09:05 PM
Rod Bearings djmichael24951 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-25-2013 08:49 AM
Rear Main Seal Leak fasthauler 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-13-2012 11:39 AM
400m rebuild with mismatched parts...... 650 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-10-2012 11:18 PM
Tags
370, 460, bearings, crank, crankshaft, dimensions, ford, journal, journals, main, rod, size, specification, specs, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
