'72 f100 brakes bleeding woes
Ok, tried to be descriptive with the title there, lol.
Basically, whats happening is I'm attempting to bleed my brakes. the problem is that 11mm is too big, 9mm is too small and the 10mm just slips on the bleer valve. I'm correct in assuming it's a 10mm, right? Every car I've ever done the brakes on has been a 10mm, even my old '76 280 Z I had.
Just trying to get the brakes bled so I can go for a nice ride and test'er out.
Well, the thing is, I don't know if there stuck or what because I can't get any tools to grip the stupid bleeder's. That's my real problem. Tomorrw, I'll have light and will go look again, but as I said, weather or not there even stuck is yet to be determined. getting a socket or wrench to grip them is. Would it be logical to put a single strip of say gorilla or duct tape in the wrench to grip it? Just trying to think of what might help..
Ok, awesome! there not even stuck! I didn't have a 3/8 deep well socket, so I went to my local autozone and grabbed one. Works like a charm. Next question, can I remove the bracket around the front bleeders?
There's a bracket, and I think it just holds the brake line to the brakesin the front. Is it ok to disconenct this, bleed them, and reconnect it? I don't want to disconecet the brake lines, just that bracket, because I can't get any tools in there to get to the valve.
Provided it is not the brake hose you can take anything you like off, including the caliper.
If you do take the caliper off (with hose connected) jam a block of wood or similar in so that the piston can`t extend and make sure you hold the caliper with the bleed screw at the top while bleeding it.
Also make sure you bleed fluid out of all the screws untill only clean fluid comes out.
Turbo Dog
21
08-23-2019 10:55 AM
john.johnson
1997-2006 Expedition & Navigator
02-01-2017 04:17 PM
