HPOP STC fitment kit question...
So far so good. Question on the HPOP STC fitting kit. The instructions indicate that a new dowel is included in the kit. Mine did NOT include a new dowel. The existing one is undamaged. Does anyone see a problem with using the old one?
Further, the kit comes with more o-rings then I have removed... are the various sizes for different years/models? Or am I totally missing something. I matched up the two I needed that slide into the slot on the engine side of the HPOP, and the one on the jam nut on the STC was already installed (the new one). I have two additional o-rings of smaller size that I do not see go anywhere. Are these extra for other setups?
Thanks,
Matt
Thanks,
Matt
The "F" kit - the second one. The one BPD sells: http://www.bulletproofdiesel.com/Pro...ctCode=6000034
on
Let me apologize for the hi-jack ahead of time here, but I have a question pertinent to this discussion that doesn't seem to warrant a new thread of its own.
I'm going to pull the HPOP cover while I'm replacing my oil cooler. However, since I don't have a HPOP leak at the moment, I'm considering simply installing the support bracket without changing out the STC. Is this a stupid idea, or a valid option?
The answer will probably be right there in black and white after I pop the cover and see what I'm dealing with, but I guess it can't hurt to have some idea of what I'm getting into before then.
I have the international C92 kit. The bracket is in there, and so are the bolts.
Whatever time doing this would save you, it saves me at least 5 times that much.
I'm that slow, but I'm not afraid to do my own work.
PS: I just finished bolting the new oil cooler back in the truck. Tomorrow its under the HPOP cover.
