I think I have a turbo R&R in my future. When I'm in there I want to install the new drain tube, and feed line. Are these the correct part numbers?
Feed line 3C3Z-9T516-A
Drian tube 6C3Z-9T515-A
Is there anything else I should reaplace or update while I am in there?
Also does Ford sell a turbo cleaning kit? If so what is the Prt #.
Sorry Im not so good on the p/n# if you go to the dealer and ask for the parts you need they will give you the right stuff's. as the old parts are not available any longer.
you may want to get a turbo install kit. that will come with new mounting bolts a flat gasket and some o-rings.
The kit contains:
3 o-rings for the drain and feed line, gasket, as well as the three bolts and spacers
Mark-when I replaced my EGR/engine coolers recently one of the gasket kits had three spacers in it. What are they for? I have a 2005 6.0 PSD and didn't find a use for them.
im not mark,but hte spacers where used in early production 6.0 that had the saddle syle turbo pedistal.they used the spacers on the turbo mounting bolts.ford cold of saved some money and jiust used shorter bolts
you might want to call gpopshop.com - they sell the garrett internal rebuild kit, seals, bearing, etc - $125. Ford does not sell this (to my knowledge). You'll need this if you are following the refurb plan from the tech folder.
