Sterring Wheel Issue 96 F-150
06-27-2010, 05:53 PM
on
My sterring wheel has slack left to right, up and down. It seems to be getting worse fast and very little noise but appears to be binding some!! I don't know where to start to fix this issue and have never worked on sterring wheel area before!! Any help would be great!!!
06-27-2010, 06:49 PM
on
sounds like the bearings in the column.... so u can replace those or replace the column.....
then stop using the wheel to pull urself in the cab :P because that really wears them out
06-27-2010, 07:48 PM
on
Thank's
I must admit back when I was 100lb's heavier I did pull my big *** up in there using da wheel!!! Ha Ha!!! You have any idea where I start. don't know anything about air bags so little scared to just dig in!!! How many bearing is there???
