AC cutting in and out 95 F150
Old 06-27-2010, 10:40 AM
nflfreak43's Avatar
nflfreak43
nflfreak43 is offline
my dad has a 95 F150 with a 302 in it. well hes had it for bout 2 years and in the entire time hes had it hes had an issue with the AC. It works great but when hes driving around in town it goes off and on, off and on. but on the interstate its constant.
i remember (i think) there being a TSB on it. but not sure.
what could be the problem?
Old 06-27-2010, 10:43 AM
Iceman_AKA_Ford guy's Avatar
Iceman_AKA_Ford guy
Iceman_AKA_Ford guy is offline
probably not keeping good pressure or the AC cluch is sticking. my dads 96 does the same thing. is there a howl when it stops putting out cold air? or dose it just shut off completely? if it shuts off completely then my guess is a short in the electrical somewheres
Old 06-27-2010, 11:22 AM
CS45's Avatar
CS45
CS45 is offline
I had this problem with my 1995 F250 351W and it was low on fron, due to the schrader valve leaking. System cannot build enough pressure so it kicks off.
Check your AC system for leaks, recharge with freon and see if that helps.
CS45
Old 06-27-2010, 02:27 PM
redlightning93's Avatar
redlightning93
redlightning93 is offline
I would suspicion two issues. Refrigerant charge is low, which needs to be confirmed with manifold guages, or the a/c clutch air gap is set too wide allowing the clutch to "slip out" at low engine RPMs.
Old 06-27-2010, 02:59 PM
Cory281's Avatar
Cory281
Cory281 is offline
Can you here the fans spinning, but no air coming out of the vents? My truck was doing that randomly. It ended up being a vacuum leak, theres a white line on the passenger side on the firewall that goes in this little valve that was leaking.
Old 06-27-2010, 03:31 PM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
^i agree that stupid white vac lines breaks
Old 06-27-2010, 04:40 PM
nflfreak43's Avatar
nflfreak43
ok. ill let my dad know to check that.
Old 06-27-2010, 06:28 PM
jade79's Avatar
jade79
jade79 is offline
Is this line and valve under the hood? Mine has been doing what you described as well. I suspected a vacuum leak behind the dash, at the switch, or one of the blend doors, but my back was just dreading laying under the dash to search for it.
Old 06-27-2010, 07:22 PM
ymeski56's Avatar
ymeski56
ymeski56 is offline
Der Postmeister
I'm bettin the low pressure cut off switch is just doing it's job, & your freon level is right around the level that triggers it.
Old 06-27-2010, 08:13 PM
Iceman_AKA_Ford guy
its under the hood. when you lift the hood look to the passenger side and you will see a white line going into a valve....BE CAREFUL the white line can be very VERY brittle.
Old 06-28-2010, 07:58 PM
Cory281's Avatar
Cory281
Cory281 is offline
Mine looked fine until I took it off and saw underneath it.
Old 06-28-2010, 08:18 PM
nflfreak43's Avatar
nflfreak43
ok. so my dad said it didnt appear as the line was leaking but said he thought maybe that valve wasnt staying open... IDK? maybe a possibility.
Old 06-28-2010, 09:10 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Off and on at low speeds, works ok on the highway.
That's not low refrigerant charge. Generally, the compressor will cycle more at higher engine and road speed because the low side pressure drops more and drops quicker.
My bet is that the fan clutch is very weak/dead and the compressor is cycling on the High Pressure Cutout Switch. Spray water over the condenser and see if it stops cycling and cools better.
That switch opens at about 375psi, so it's beating the compressor to death. Being a 95, the fan clutch is about 5 years past due, at least as far as the AC is concerned.
Old 06-28-2010, 09:12 PM
nflfreak43's Avatar
nflfreak43
ok.. ill help my dad by doing that with him.
ufvj217
62
03-16-2016 07:51 PM
lawdawg79
1999 to 2016 Super Duty
08-16-2015 02:52 AM
2tall91
04-14-2015 11:34 PM
A_G
General Automotive Discussion
16
07-27-2005 12:17 AM
burgerman
03-29-2004 07:05 PM
Quick Reply: AC cutting in and out 95 F150
