SEIZED UP 2006 F150
SEIZED UP 2006 F150
My 2006 F150 with 77k seized up on friday. Sounds like a bad injector flooded the engine, caused hydrolock, and then bent a rod. I called the dealership today and they said the only fix is a new engine. Does anybody have any experience with getting a problem like this fixed and I thought I heard the 2005's had this problem and Ford extended their warranty? Need suggestions!!! I have 3 payments still left and now the dealership is telling me I gotta buy a new engine for $5,800.00.
if the cause was the injector there is a program that covers the injector and all related damage
07m08 is the coverage program number
hope this helps good luck..
Michael A. Berardi Ford Motor Company
Director P. O. Box 1904
Service Engineering Operations Dearborn, Michigan 48121
Ford Customer Service Division
August 1, 2008
TO:
All U.S. Ford and Lincoln Mercury Dealers
SUBJECT:
Customer Satisfaction Program 07M08 – Supplement #1:
Certain 2005 Model Year F-150, F-Super Duty, Expedition, and Navigator Vehicles
with 5.4L 3V Engines – Extended Warranty Coverage on Fuel Injectors
Ref:
Customer Satisfaction Program 07M08 – Dated December 11, 2007
REASON FOR THIS SUPPLEMENT
Based upon dealership technician input, the service procedure has been revised and labor allowance
increased for the repair of the Expedition and Navigator vehicles. The service procedure and labor
allowance for the repair of the F-150 and F-Super Duty remain the same.
PROGRAM TERMS
This program extends the warranty coverage on the fuel injectors to 11 years of service or 120,000
miles from the warranty start date of the vehicle, whichever occurs first. Coverage is automatically
transferred to subsequent owners.
VEHICLES COVERED BY THIS PROGRAM
Vehicle Line Model Years Assembly Plant Production Dates
F-150 2005 Dearborn Assembly Plant Job #1 2005 – Job Last 2005
F-150 2005 Norfolk Assembly Plant Job #1 2005 – Job Last 2005
F-150 2005 Kansas City Assembly Plant Job #1 2005 – Job Last 2005
Expedition 2005 Michigan Truck Plant Job #1 2005 – Job Last 2005
Navigator 2005 Michigan Truck Plant Job #1 2005 – Job Last 2005
F-Super Duty 2005 Kentucky Truck Plant Job #1 2005 – Job Last 2005
Affected vehicles are identified in OASIS.
REASON FOR PROVIDING ADDITIONAL COVERAGE
In some of the affected vehicles with 5.4L 3V engines, the fuel injectors may stick open or closed.
This concern could cause the check engine light to illuminate along with a hard starting and/or rough
running engine condition. In some instances, continued engine operation with a stuck open/closed
fuel injector could result in powertrain damage.
Ó
Copyright 2008 Ford Motor Company
SERVICE ACTION
If an affected vehicle experiences any of the conditions listed above, dealers are to perform the
specific diagnostic procedure in Attachment III using Special Service Tool Kit# TKIT-2007FI-FLM
which were shipped to dealers at no cost in December of 2007. If the vehicle concern is found to be
caused by a stuck open or stuck closed fuel injector, the fuel injector will be replaced on affected
vehicles at no charge to the vehicle owner.
PLEASE NOTE: This extended coverage program only applies to stuck fuel injectors and
related damage caused by stuck fuel injectors. During diagnosis, if other concerns not related
to stuck open or closed fuel injectors are found, they are not covered under this program and
are the responsibility of the customer if the vehicle has exceeded the time and mileage of any
other applicable warranty coverage. Customers who received letters announcing 07M08 and
bring their vehicles into the dealership for any reason should be advised that this program
only covers repairs related to defective injectors. The owner letter informs customers of this
issue.
issue.
Attachment I: Administrative Information
Attachment II: Labor Allowances and Parts Ordering Information
Attachment III: Technical Information
Customer Notification Letter
QUESTIONS & ASSISTANCE
Special Service Support Center (Dealer Only) …………….…………………….1-800-325-5621
Sincerely,
Michael A.Sincerely,
Hey Michael,
Thank you for the reply. Unfortunately the info you posted was for the 2005 F150' s and mine is a 2006 and I believe there is no campaign on the 2006 models. Have you hear of this problem on the 2006's? Was there a different injector used on the 06 versus the 05? I love my Ford truck. It was the first brand new and american made car I have every bought and this is breaking my heart.
You've got something i've never heard of on an 06.....not to say its not happened but i've never heard of it. Sadly, you are probably looking at a new engine.....i'd check out what some of the online places charge for a shortblock (or long block) and see what a private mechanic would charge to swap it out.....
For example...a ford shortblock can be had from these guys for 1100 bucks...
Silver State Ford Parts (Formerly DIRECTFORDPARTS.COM)Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Does the guy work on Fords a lot? I wouldn't let just anyone put a rod in your truck. I would compare labor rates with the dealer and let the dealer do it if possible. There can be a large difference in rates between dealers. The dealer I used to work at charges $105/hr and the new one charges $85/hr and they are only 15-20 miles apart. The dealer I'm at now is cheaper than some independent shops around.
