You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm looking for a rear center cap to fit the factory 8-lug alcoa alum. wheels. Must be a rear center cap for the full-floating 10.25 sterling axle. Ford part number F5TA-1A096-UB. I only need one, but would buy set if price is right. Or if you know anyone with them send a name and phone number, my number is 931-935-5005. Not sure what years they were used but my truck is a 1987 and the wheels are from a 1995. Thanks for looking.
Reason: add phone #
Here are some aftermarket ones that work better than the originals, but you have to have 7/8 in. lugnuts.
If you need any more info you can PM me.
__________________
-Ian 1995 F-350 Crew Cab 4x4 5-spd 4.10s 7.3L Powerstroke 315,000 miles and counting. Mods: 6637, 3in Diamond Eye downpipe to 5" mitre cut stacks Auto Meter gauges, cab lights, Stage 1s, 6.0L intercooler, Cale's tunes. 2004 F-250 FX4 CC 6.0L, 111,000 miles, ARP studs, EGR dissapeared... Tuned by Innovative
"It is a fine line between genius and idiocy"
Numbers marked on parts after 1956 are not part numbers, they are either ID engineering or casting numbers.
ID engineering number F5TA-1A096-UB is related to 1995. Did you install later wheels on your truck?
Since there are myriad center caps, posting a pic of the one you need would be a big help.
F5TA-1A096-UB is an ENGINEERING number, which is a PART #F5TZ-1130-J. Most Ford dealers should stock that-it retails for about $66 bucks. And yes it fits later (95-97) trucks.
Even though your stock ones have the four tab design, the ones I pasted the link to will work great and are an upgraded design that work much better! I have used several sets.
__________________
