Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 06-26-2010, 09:18 PM
ranger714 ranger714 is offline
Garage is empty, add now
ranger714 is starting off with a positive reputation.
ENGINE IDLES FINE,DIES WHEN PUT IN DRIVE
1995 V6 3.O AUTOMATIC, MY SONS GIRLFRIEND WAS DRIVING,SHE SAID IT WAS RUNNING FINE UNTIL SHE PULLED INTO A QUICK TRIP GAS STATION.WHEN SHE CAME OUT SHE CRANKED UP AND WHEN SHE PUT INTO DRIVE OR REVERSE THE ENGINE CUT OFF.
  #2 (permalink)
Old 06-27-2010, 08:25 AM
pawpaw pawpaw is offline
pawpaw has a great reputation on FTE.pawpaw has a great reputation on FTE.pawpaw has a great reputation on FTE.pawpaw has a great reputation on FTE.pawpaw has a great reputation on FTE.pawpaw has a great reputation on FTE.
Acting out IAC maybe.
Or maybe the torque converter clutch is locked up.
What happens if she pushes the OD switch on the end of the shift lever, so the "OD Off" dash indicator is lit & then tries putting it in gear????
What happens if she puts it in 2nd & tries to move off????
__________________
99 Ranger XLT 4dr 4x2 4.0L 5spd Auto 3.55L/S Payload Pkg2 Tow Pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed, autograph your work with excellence
  #3 (permalink)
Old 06-27-2010, 09:49 AM
THE AEROSTAR IS BEING TOWED TO MY HOUSE,IT SHOULD BE HERE BY NOON.IT WILL BE EASIER FOR ME TO CHECK.I WILL TURN OFF THE OD AND CHECK THE 2ND AS SOON AS IT ARRIVES.THANKS AND I WILL POST AS SOON AS I CAN.
  #4 (permalink)
Old 06-27-2010, 10:26 AM
00Harleydavidson 00Harleydavidson is offline
00Harleydavidson is starting off with a positive reputation.
After you get to try it out you will be more able to diagnose the problem. Could be a fuel problem also. Enough fuel to idle but not enough to pull a load. I'll be interested to see if you can rev the rpm's up when in park or if the vehicle stumbles. Also lets hope it isn't a computer problem. Let us know more when you look at it.
  #5 (permalink)
Old 06-27-2010, 11:00 AM
Cranked up the van,it revs up fine in park.Also on the column its park/reverse/nuetral/od/drive/2nd/1st.It will stall in any position except park or nuetral.
  #6 (permalink)
Old 06-27-2010, 11:04 AM
Could the modulator be the problem?
  #7 (permalink)
Old 06-27-2010, 11:13 AM
Is the CEL lit???? if so pull & post All of the trouble code Numbers.
Maybe try disconnecting the IAC, the engine may idle rough or stall, but you can keep it going with a little accelerator pedal, then see if it'll move wihout stalling.
If not, switch the OD Off & shift into all gears.
If no joy, I'd suspect the torque converter clutch is locked up, thats sorta like leaving a straight drive in gear when coming to a stop.
How is the tranny fluid condition????
__________________
(Ben Franklin)
  #8 (permalink)
Old 06-27-2010, 11:35 AM
NO LIGHTS ARE ON THE DASH,DISCONNECTED THE MASS AIR FLOW SENSOR,WHEN YOU PUT IT INTO GEAR IT MAKES A LOUD CLANKING NOISE AN QUITS.ASHLEY JUST TOLD ME WHEN SHE PULLED INTO THE STORE THE VAN STARTED VIBRATING PRETTY BAD AND ALL THE GAUGES WERE JUMPING AROUND.
  #9 (permalink)
Old 06-27-2010, 11:36 AM
ALSO THE FLUID LOOKS OK AND THE FLUID LEVEL IS FINE
  #10 (permalink)
Old 06-27-2010, 11:42 AM
Kinda sounds like the torque converter clutch is locked up for some reason.
The dash warning lights coming on & the gauges jumping around on her, was likely caused by the engine about to stall
You need a tranny man to chime in & enlighten us some more.
__________________
(Ben Franklin)
  #11 (permalink)
Old 06-27-2010, 11:50 AM
PAW PAW , YOU THINK I NEED TO REPLACE THE TORQUE CONVERTER?
  #12 (permalink)
Old 06-27-2010, 12:07 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is starting off with a positive reputation.
Did she get gas at her last stop and thereafter it started acting up? Maybe water in the gas. Try a bottle of dry gas in tank. Also try cleaning MAF sensor and/or look for a leaking vac line.
  #13 (permalink)
Old 06-27-2010, 12:14 PM
I JACKED UP THE REAR END,CRANKED UP AND SHIFTED FROM NEUTRAL TO DRIVE AND THE WHEELS TURN WITHOUT THE ENGINE STALLING
  #14 (permalink)
Well we don't have enough vehicle history to jump to that conclusion just yet & I'm not a tranny guy, I know just enough about em to be dangerous!!!! lol
You likely need input from a Ford tranny tech.
Is the OD light on, or flashing????
Did you ever try turning the OD OFF, by pushing the switch on the end of the shift lever, until the OD Off light in the dash comes on, then trying to shift into gear????
This is supposed to deactivate the torque converter lock up solenoid/clutch, so maybe exercising the OD switch would wake something up?????
Has this vehicle had any tranny problems or repairs before this event????
__________________
(Ben Franklin)
  #15 (permalink)
Old 06-27-2010, 12:19 PM
THERES NO WAY TO DEACTIVATE THE OD, THE VAN HAS BOTH AN OD AND DRIVE POSITION ON THE COLUMN
Tags
2001, 2003, dies, drive, engine, f150, fine, ford, gas, gear, idles, kills, powerstroke, put, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
