Help! 2002 Ranger Won't Turn Over (Good Battery, Dash Lights, 2.3L, MT, 40k miles)
Could anybody throw in their two cents on this problem? I have an '02 Ranger that will not turn over even with a good battery. When the key is inserted and turned, all the dash lights and headlights come on but the engine does not turn over. Could it be....
*Power Control Module?
*Ignition Module?
*Key?
*Whatever the part is called that reads the Key's security code (pls advise)
*Clutch Switch?
I am trying to avoid getting the run-around at the dealer and be able to drive to work on Monday! Thanks for your help
*Ignition Module?
*Key?
*Clutch Switch?
...Welcome 2002RangerDriver and RangerPilot, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
I think your 02 has patts and that could be keeping if from turning over. It could also be the neutral switch, cables, relays. Have you done anything that would affect the patts? How did the problem start? The part that reads the key code is the power control module and the "antenna loop" around the ign switch.
Dave
on edit: woops,I see its a manual, so it could be the clutch switch instead od the neutral switch..
Dave
`u can unplug the neutral saftey switch on the back of the clutch pedal and try it then, that would eliminate that problem... then i would test to see if the starter itself is bad... easiest way would be to have 2 ppl and a multimeter and have someone turn it over while u are testing it...
Matt
p.s. yes does it click at all, does the starter motor spin? any noises at all
Matt
