Message Center not working - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-26-2010, 09:43 PM
motopsyko32's Avatar
motopsyko32 motopsyko32 is offline
motopsyko32 is starting off with a positive reputation.
2000 Ex Limited. Message Center not working at all. The buttons light up when the head lights are on but thats about it.
Anyone care to share troubleshooting tips? Fuse? Loose wire? Easy fix?
Thanks!
Old 06-26-2010, 10:01 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
Could be a fuse, also check the fuse to the cigarette lighter on the dash.
There's also a post on this site pertaining to "cold solder joints" in reguard to the message center.
Old 06-27-2010, 12:36 AM
after starting this thread I found the solder one...
Old 06-27-2010, 02:02 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Most likely its the solder that gave way.
Old 06-27-2010, 04:32 PM
so i checked the fuse and sure enough it was blown. i replaced it but the message center did not come to life
Old 06-27-2010, 04:36 PM
UrbanXX's Avatar
I'm sure you done this, but I will ask the question anyway. Did you turn the message center on with the motor running?
Old 06-27-2010, 06:48 PM
turn it on?
I started the car... hit each button individually two or three times, held both buttons down for 5 seconds, etc.
Is there another way to turn it on that i am not aware of?
Old 06-28-2010, 05:09 PM
Ex03AK's Avatar
Ex03AK Ex03AK is offline
Ex03AK is gaining momentum as a positive member of FTE.
Thanks!
This is a common problem. There are several resistors on the display panel's circuit board that have come loose or fallen off. The chips look like a flat silver bar about 3/8" long x 3/16" wide and have a 2-digit number like 60 or 70 on them.
You do have to remove the console completely to get at the circuit board but it is simple. It is only 2 screws in either the sunglasses or door opener compartment (It's been awhile). Once you remove the screws, you have to pop the rear off by pulling down on it. It feels as if you might break it but it's OK. Now pull rearward until the tabs at the front of the console are released and it is loose. Just detach the wiring harness near the front and you can take it inside to do the rest. Put it on a towel so you don't scratch it up.
WARNING! Watch out for a falling chip as you remove the console. One might have completely fallen off of the circuit board. They are very small and hard to find otherwise.
It took longer for my soldering iron to warm up than it did to remove the console and circuit board. Just make sure you use a lower wattage iron and you might as well re-do all the chips at once.
Here is a link to a thread with DETAILED instructions to an easy fix. See post #4.
http://www.ford-trucks.com/forums/44...-gone-out.html
Good luck!
Stew
Old 06-28-2010, 08:15 PM
thanks thats the thread i read a bunch of times before i punked out figuring i would crack the plastic trying to remove it
Old 08-16-2010, 04:20 AM
cudamank cudamank is offline
cudamank is starting off with a positive reputation.
Thanks for the help, I just had this same problem on my 05. One screw then the console pulled down. and then it was just a matter of resoidering those chips.
Old 09-22-2010, 12:37 AM
under6ft under6ft is offline
under6ft is starting off with a positive reputation.
The only thing different then the linked instructions is that in the Excursion you can't just remove the message center unit. You need to pull down on the front of the whole Message Center/Temp Controls/Storage/Light console, unscrew the one screw that cudamank mentions, and then disconnect the three cables. You can then remove the small message center console and open it up. Just be careful when you open it because a chip might be loose and if you drop it it could be hard to find. Make sure you also get solder clean up tape (forget what we called it when I worked as an electronic tech), because the chips are so small you can end up with two much solder and cross connect two of the chips. Just finished it up and it WORKS! Thanks for all the help.
Old 09-22-2010, 10:19 PM
labman1014's Avatar
labman1014 labman1014 is offline
labman1014 is a name known to alllabman1014 is a name known to alllabman1014 is a name known to alllabman1014 is a name known to alllabman1014 is a name known to alllabman1014 is a name known to all
well i got my console down and opend up the display to find a chip missing. it is one of the 680. can u find them around of am i screwed? i can tell the console has been down b4 since one of the clips was broken. i know i was careful to watch for falling chips.....
Old 09-22-2010, 11:15 PM
If it is only a resistor as a few post mention then you should be able to find it fairly easily. The 680 may designate a certain level of resistance. It might even be something Radio Shack would have. If not a industrial electronic supply store should definitely have it. I would take your board with you because if 680 doesn't mean anything they could at least test the resistance across one of the other 680 chips to know what it is.
auto lamp feature not working gustrider4 1999 to 2016 Super Duty 0 12-15-2015 09:36 PM
2005 Navigator Message Center Question Waylon77 Expedition & Navigator 10 09-25-2015 11:37 AM
Message center dead in the water Naked squirrel 1999 to 2016 Super Duty 3 10-17-2013 09:08 AM
Message Center Jim Brock 2004 - 2008 F150 12 08-06-2011 08:44 PM
Message Center Brightness osheam Explorer, Sport Trac, Mountaineer & Aviator 0 07-28-2009 12:01 PM
Tags
03, 05, 2003, center, enthusiasts, excursion, f150, f250, ford, forum, fuse, info, message, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
