Aerostar Ford Aerostar
dies when put into drive
Old 06-26-2010, 06:53 PM
ranger714's Avatar
ranger714
ranger714 is offline
1995 AEROSTAR 260,000 MILES V6 3.0 RUNS FINE IN PARK OR NEUTRAL BUT STOPS RUNNING WHEN YOU SHIFT INTO REVERSE OR DRIVE.VAN WAS RUNNING FINE,PULLED INTO A STORE AND WHEN THE VAN WAS CRANKED TO LEAVE(JUST A FEW MINUTES IN THE STORE)IT WOULD NOT GO.
Old 06-27-2010, 12:29 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
Check for a vacuum leak, like at the vacuum tree at the rear of the intake manifold.
Sometimes if you don't hold the key to the start the engine long enough, it will backfire through the intake. That has blown off vacuum lines and caps onmy van at least a few times. This make the engine run horribly, when it was fine a minute before. It may or may not throw a CEL.
Old 06-27-2010, 07:13 AM
ranger714's Avatar
ranger714
TRYING TO GET AS MUCH FEEDBACK AS POSSIBLE,THE VAN IS SITTING AT A QUICK TRIP STATION (STORE)PEOPLE I HAVE ASKED HAS SAID ITS PLUGS,SOMEONE EVAN SAID IF THE TAIL LIGHTS WERE OUT IT WOULD STALL IN GEAR.
Old 06-27-2010, 11:28 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Does the engine die slowly like the ignition was shut off..? Or does it stop turning abruptly like the a manual that you dumped the clutch? You may have a wire issue. When you put the tranny is drive the engine moves and maybe causing a connector to come apart...Try going to Neutral really fast see what happens..
Dick
Old 06-27-2010, 11:44 AM
ranger714's Avatar
ranger714
THE ENGINE CUTS OFF ABRUPTLY.IT RUNS GOOD IN PARK OR NEUTRAL BUT ANY OTHER GEAR IT STALLS.IT MAKES A LOUD CLANKING NOISE WHEN YOU SHIFT INTO DRIVE THEN DIES.
Old 06-27-2010, 11:54 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Tranny or torque converter is what comes to mind..Pull the fuse for the converter clutch maybe its locking when you shift to drive...You could jack the rear up and see if once the tires spin the engine will keep running...
Almost sounds mechanical...Good luck..
Dick
Old 06-27-2010, 12:11 PM
ranger714's Avatar
ranger714
jacked up the van,when you crank it and shift from neutral to drive the the wheels spin
Old 06-27-2010, 12:37 PM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
I sugest TC. try to cut TC lock-up wire near tranny connector, may be you have bad wiring ore short transistor in PCM, but I saw bad insolation inside trannies, especially allison on LIAZ buses, wire insolation is usually bad if truck/bus was overheated. and TC is groun controlled, when wire is bad and short to ground TC is olways lucked up. To drive bus to me they pushed it to 5 MPH and put tranny into L position and slowly drow to me...
Old 06-27-2010, 04:13 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Sounds like TC's Locked possibly. locate the fuse or wire..
CABGx3
11-25-2015 10:50 AM
DreadyDiggs
12-06-2014 05:11 PM
lvin4jc
01-16-2012 07:07 AM
joelmilot
Crossovers
01-06-2011 08:34 PM
kynnhoj
Modular V10 (6.8l)
08-05-2005 07:03 PM
Quick Reply: dies when put into drive
