Need help 06 5.4l misfiring code
hey guys need advice.
Well my truck started shakin and jerking on the highway then after a while the CEL came on, so took it to get it scanned and got the P0304 code twice for the #4 cylinder misfiring.
So decided to just go ahead and change all my plugs, and yes i ran into the plugs breaking in the heads! but anyways i got them out. Come to find out that it still shakes and jerks, of course i went ahead and put a new coil on the number 4 cyl. Ran it up and well, the jerking stopped but its still shaking and the rpm fluctuates.
Once again i went to get it scanned and now it brought up the #1 cyl. is misfiring, so yea, i went and replaced that coil also and no fix!
So in conclusion i have changed all plugs replaced coils in #4 and #1 cyl. It still shakes at idle, rpm fluctuates, and when i press down on the gas pedal it tries to stall, also the P0301 #1 cyl misfire code keeps showing up no other codes have popped up
Any ideas? I'd appreciate it
I would say that you may have gotten a bad coil for the #1 plug but if the issue is still occurring you might want to consider replacing all the coils.
4x4 what I would say for you is it may be time to replace plugs and maybe the coils as well. Some people have to replace the boots as well at the same time it will just depend on what all is going on, how many miles you have your truck, and your driving habits.
Is there any trick to changing the coil on plugs. At 100K miles my truck misfired so a mechanic changed my plugs and truck ran fine for 5000 miles then misfired again. Had mechanic change #6 cylinder COPS and was good for another 5000 miles. Now it is misfiring again and I think I will change all of the COPS myself and was wondering if there were any tricks of the trade. Is there oil needed to lubricate or anything like that.
Did you use too much Dielectric grease on the spark plug or in the plug boot? It is only supposed to be used inside the boot's first 1/8"-1/4". I also use it where the boot joins to the coil. Remember DIE-lectric doesn't allow currant to flow. Do not use it on the plug's tip.
When you reconnected to coil connectors to the coil pacs did you check to make sure none of the weather-pac seals fell out. Without them water can get into the connectors and cause shorts.
When you originally removed the spark plugs was there evidence of water in some or all of the plug bores? If so, the Boots should be changed as they are deformed from heat and won't keep water from entering the bore which may cause misfires.
One final thing. Try disconnecting the battery for a while to reset the Keep Alive Memory, KAM. The pcm will relearn new driving parameters.
There's my ideas
nhredneck
2004 - 2008 F150
02-03-2018 11:39 AM
97fordLVR
04-28-2011 07:10 AM
