Piston Shape Plastic Part from Fluid Filter
I put a used 4R70W transmission in my 2003 F-150. Unbolted the oil pan and pulled the filter straight down and laid it in the oil pan. When I poured the oil from the transmission pan into an oil bucket, this yellow plastic plug with a stem fell out of the oil filter. I guess it goes back into the spout that pushes back into the valve body.
Question is, does this yellow part go in with the stem facing out of the spout or the stem face toward the inside of the filter.
It's has an o-ring around it, but it fits very loosely in the spout either way. Is it suppose to?
Please help.
Please help.
Cannot believe anybody hasn't jumped in yet on this.
It is a temporary plug installed in the dip stick filler tube hole in the transmission by the manufacturer.
During vehicle final assembly, when installing the dip stick tube, it is pushed into the pan.
If you found it in there, it means (most likely) that the pan has never been removed from that transmission before.
Thank you, Dialtone. I dropped my Expedition's pan yesterday, and was scared so much because of this yellow piston part. I didn't know how or where this part goes back to. I checked the service manual to no avail info. Finally, I checked with a local Ford dealer parts clerk, and he checked with a mechanic who said that the part could be tossed, but did not explain it's from the tube. So I was half relieved that I didn't do anything wrong to get the part dropped down, but still was not sure where it came from.
You made it clear, and I fell confident to discard it.
Tractionless
6.4L Power Stroke Diesel
16
07-14-2020 05:23 AM
todd230
2009 - 2014 F150
52
09-30-2011 10:40 AM
