My 69 F250 - Ford Truck Enthusiasts Forums
My 69 F250
Old 06-24-2010, 07:25 PM
Powder river Powder river is offline
Powder river is starting off with a positive reputation.
My 69 F250
The ignition switch on my F250 has finally worn out. Parts list shows D1AZ-
11572-C and the one I received as a replacement is a D1AZ-11572-A.
The -A seems to have a stud out the back to hold the plug tight and the -C
doesn't seem to have one. Got any ideas?
George
Old 06-24-2010, 11:27 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
Did you try your frindly local parts place? I would recommend NAPA, mainly because I bought a cheapie from another place, and it blew apart on me. It was only a month old, and all the guts came flying out. Get a good one, and it'll last, and you wont have to worry about it. Mine has that stud on tha back too. Try telling them it's a 72 next time.
Old 06-25-2010, 01:29 AM
The one I got was from Vintage ford. I'll check with them again about a 72 switch thanks for the advise
Door Lock and Ignition Set WARDNEAL 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-08-2012 10:44 AM
1976 F250 Ignition Switch Housing F250Stu Electrical Systems/Wiring 4 01-04-2010 10:46 AM
1965 Ignition Switch SW-353 F250GH 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-06-2009 06:47 PM
ignition switch removal...when key is gone 66F100Again 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-09-2006 06:41 PM
Ignition Switch Part # btacarlton 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-17-2006 03:01 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
69, f250, ignition, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
