Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-24-2010, 08:26 AM
mcbsff mcbsff is offline
Garage is empty, add now
mcbsff is starting off with a positive reputation.
2007 Expy EL Tranny Maintenance?
I just bought a used 07 Expy EL. 2WD, 36K miles. This will be my wife's DD - no harsh service. That being said, I tend to keep my vehicles a long time.
As it is new-to-me, I took it to the dealer for the 30K service. I specifically asked them to change the transmission fluid. I asked if they drop the pan and change the filter. They said there is no filter to change, just a screen. They just use their tranny flush machine.
When I picked it up, they said they did NOT service the transmission. They said the service interval for the transmission is 100K.
Anyone know if this is correct? Is this reasonable? I'll admit to being a little gunshy, as this is replacing an '02 Odyssey with the self-destructing tranny.
  #2 (permalink)
Old 06-24-2010, 10:52 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
It's in the manual. Yes, 100K for normal service, 60K for severe service.
They are completely wrong about the filter. It's part . 7L1Z7A098A. Call them and ask what this part number is for then? Morons.
Motorcraft FT171 FT-171 Transmission Filter Kit 06-09 - Appleton City - Bonanzle
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 06-24-2010, 03:25 PM
Thanks for the reply.
I double-checked my manual, and searched online. I could not find anything that referred to a 100k maint interval on the tranny. Just belt, plugs, and coolant at 100k.
Before getting the service, I spoke with 2 Ford dealers, both said "we don't pull the pan, we just flush."
Either way, If it's 100k svc, I wont worry about whether they pull the pan or flush for another 60k!
  #4 (permalink)
Old 06-24-2010, 03:26 PM
berry1234's Avatar
Yeah but them not pulling the pan worries me. It's not hard and is the right way to do it.
__________________
  #5 (permalink)
Old 06-29-2010, 06:23 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
We flushed our 2007 Expy @ 44,000 miles,the book does say 100,000 miles but its my money and i believe in changing fluids,hard to believe a dealer would turn down service work $$$$$ .
__________________
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 sunnybrook 31 bwks with 3 slide's, truck & RV 20,900 #'s all at the scale .
My truck and 5er.
  #6 (permalink)
Old 06-30-2010, 04:15 PM
RoyC RoyC is offline
RoyC is starting off with a positive reputation.
Quote:
Dropping the pan clearly is the old way of doing it, but it is not the correct way. A heated flush machine gets all of the old fluid out. This has been the standard for a number of years and for 230,000 miles this is the way my Excursion was serviced every 30K with absolutely with no issues.
__________________
2010 EB Expedition 4X2.
  #7 (permalink)
Old 06-30-2010, 04:25 PM
berry1234's Avatar
Quote:
Standard by Jippy Lubes. Not changing the filters can have it's draw backs. Your just pushing anything the screen collected all through the system. It's easier to flush that's why places do them.
__________________
  #8 (permalink)
Old 06-30-2010, 06:45 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
most places don't change the filters anymore. they flush the tranny backwards with hot fluid.
there was a problem a few years back with some Fords and other vehicles that caused this newer trend. I know many Fords specifically had their factory filters replaced with a different one and that caused issues.
I'm with you on the need for a new filter. But in this day & age, most shops would rather do it the easier (read cheaper/faster) way than crawl under there and remove a pan and possibly have the gasket leak...not to mention the mess it makes.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #9 (permalink)
Old 07-01-2010, 10:35 AM
berry1234's Avatar
I agree Tylus. While I see the value in exchanging all the fluid in the system, I don't see why they can't put a new $20 filter and drop the pan also.
__________________
  #10 (permalink)
Old 07-01-2010, 10:58 AM
IF, the tranny has a filter, by all means, change it out as directed by service manual. However, many newer trannys do not have filters they have a screen. I the words of an ex Ford transmission design/testing engineer...if there is junk in the screen, get ready to rebuild the tranny.
__________________
  #11 (permalink)
Old 07-01-2010, 11:03 AM
berry1234's Avatar
Yes, which our trannys do have- a filter. The tech was wrong in saying they do not.
And I agree, if you see chunks/junk in the filter, not good. But you wouldn't know this if the pan was never dropped.
I don't know if it would be optimum to drop pan, change filter then flush or vice versa.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
