How to remove cooling fan pulley assembly for '96 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-23-2010, 08:32 PM
royt911 royt911 is offline
royt911 is starting off with a positive reputation.
1996 Ford Ranger 3.0 5 speed. The title says it all. I have my new motor ready to put back in my truck but the fan assembly is in the way. I rented the tool from Advanced Auto that my Haynes book says to use. The tool is U shaped and it is suppose to fit over a square point on the pulley. The problem is that there is nothing square to put it on. There are 4 bolts holding on the pulley and the side of the pulley towards the motor is round. And there is nothing on the other side There is a picture in my Haynes book where to put this square tool but I don't see it on my pulley. My old engine sits beside it and it is the same way. My engine is sitting half way in my truck mounted to an engine lift. Please help because there is not enough room with the fan in the way.
Old 06-23-2010, 11:22 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
The tool slips over the four bolts that hold on the pulley. Holding the pulley keeps it from turning while the fan clutch is unscrewed from the front of the water pump shaft.
Old 06-23-2010, 11:45 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
What Ranger pat said & the threads might be left hand. If they are turn clockwise to loosen.
Old 06-24-2010, 08:51 AM
Well they gave me the wrong tools then. Their tool was too thick to slide in. The only thing it could grab is the end of the bolts and they are not very long. The bolts are deep inside the pulley so I can't reach them with a wrench.
Old 06-24-2010, 09:55 PM
Well I got it off thanks to a very large pipe wrench I borrowed from work. It was large enough to go around the pulley. Ford should have designed this better so you can put a tool on it.
radiator fan rubs on crankshaft pulley 41505379 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-05-2015 04:21 PM
GUIDE: How to remove the Water Pump in a 1990-1997 4.0L OHV V6 Ford Aerostar Lee Binder Aerostar 5 02-19-2014 03:28 PM
Help planning Power Steering Pump for 223" BurnerDoc 1957 - 1960 F100 & Larger F-Series Trucks 2 01-26-2014 04:01 AM
Replacing the Water Pump Info fixxxer-upper 6.0L Power Stroke Diesel 23 10-10-2013 05:11 PM
Tensioner pulley superrangerman2002 Ranger & B-Series 5 02-19-2003 08:17 PM
Tags
2001, 30, 86, cooling, explorer, fan, ford, motor, powered, problem, pulley, ranger, remove, removing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
