code P132B
06-23-2010, 09:43 AM
on
code P132B
Hello Yall I got a CEL went to NAPA It looks like a P132B we cleared the code the truck runs perfect can someone shed some light on this?
Thanks
06-23-2010, 10:36 AM
P132B = Turbocharger/Supercharger Boost Control "A" Performance
06-23-2010, 11:28 AM
P132B is a 2003 engine specific code that is usually set when the turbo VGT hasn't been able to complete a "learn" count.
06-23-2010, 11:41 AM
Check amd make sure you do not have any exhaust leaks, and there are no leaks in the intake tract. Also check your egr valve.
06-24-2010, 09:17 AM
on
Thanks guys, the CEL hasn't returned the truck runs good. Maybe it was a hicup of some sort I have about 82K on it. I suspect some of the problem is it just doesn't get used with a load on it very often.
06-24-2010, 10:30 AM
Its usually a sign that the turbo is starting to stick a little.
06-24-2010, 10:49 AM
Quote:
Originally Posted by
deepsouthdrilling
Probably true, and having some fun may be all it needs to fix it.
Restlesswildman
06-26-2016 10:17 PM
Edogsf350
06-07-2016 08:54 PM
stitch89
12-19-2015 09:18 AM
CoalRollinX
05-01-2013 09:19 PM
PoPs 03DEX
08-10-2011 04:26 PM
03 ,
60 ,
boost ,
code ,
control ,
diesel ,
engine ,
excursion ,
f250 ,
f350 ,
ford ,
hicup ,
p132b ,
powerstroke ,
truck ,
turbochargersupercharger
