What are the 1995 5.0L engine specs? - Ford Truck Enthusiasts Forums
Old 06-23-2010, 09:42 AM
teezy teezy is offline
teezy is starting off with a positive reputation.
Does anyone have the break down of the motor? comp,cam specs?
Are the heads the E7's that were put on the mustang 5.0L?
Old 06-23-2010, 11:27 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Almost all 5.0 motors built after 1987 were the same except for a few parts. They all use the same block, heads, crank and connecting rods, the HO version got either forged or hyper pistons(depending upon the year) while the non-HO motors got cast slugs, but in all cases nominal CR was 8.8-9:1. The cam installed was somewhat vehicle specific, the HO got a unique roller cam while the trucks motor had a relatively small flat tappet up to 1991 that was switched to an equally small roller in '92 and then again to the "Explorer/F4TE" roller cam in '94. The intake, timing cover and water pump, oilpan and pickup, and accessory brackets are all vehicle unique too.
Cam specs at the valve.
Pre '92 truck flat tappet and '92-'93 roller: 0.379/0.395" lift, 244/256 duration
'94+ Truck roller: 0.422/0.448" lift, 256/266 duration
'87+ HO roller: 0.444/0.444" lift, 266/266 duration
Old 06-23-2010, 12:10 PM
Do the pistons have valve reliefs in them?
Old 06-23-2010, 03:15 PM
Conanski's Avatar
HO pistons do all others don't.
1985 F150 5.0 MPFI sensor specs. hutch246 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 01-22-2017 01:25 PM
Does anyone know the specs? Chris.Case 1987 - 1996 F150 & Larger F-Series Trucks 5 07-03-2014 07:58 AM
What are the towing and payload specs for my 1992 Ford F150 Custom 5.0L 302 5-speed? 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 0 02-28-2011 10:48 AM
5.0L valve adjustment Fordman2822 1987 - 1996 F150 & Larger F-Series Trucks 5 02-19-2011 06:05 AM
anyone know torgue specs palace55 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-28-2010 10:59 PM
Tags
1995, 1996, 50, 50l, 5l, engine, f150, ford, information, specifications, specs, truck, trunk, v8, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
