New 6.0L PSD Factory Stopwork? - Ford Truck Enthusiasts Forums
Old 02-07-2003, 06:51 AM
Jaybirdut Jaybirdut is offline
Jaybirdut is starting off with a positive reputation.
Question New 6.0L PSD Factory Stopwork?
I just received my new 2003 F350 CC, LB, 6.0L PSD three days ago. It is great so far. I heard from my son yesterday that Ford has stopped production on the 6.0L PSD. One dealership in Salt Lake City has already refunded the full amount of three trucks to the owners because they keep losing the engine after 200-600 miles. On guy had two engine replacements and they finally refunded the full amount of his truck. Anybody heard about this? I knew there would be some recalls, but this sounds serious.
Old 02-07-2003, 09:36 AM
bricot bricot is offline
bricot is starting off with a positive reputation.
Check out the thread called New Powerstroke Durability... there is a story in there that follows what you're talking about.
Old 02-11-2003, 01:58 AM
seagal41 seagal41 is offline
seagal41 is starting off with a positive reputation.
Yikes! Not that I didn't believe what I was being told but ordered one from the factory. Actually significant other ordered before finding out what I found out. I'll keep you posted on any problems here. I hope it's exceptions rather than the rule. Did anyone hear if production was actually stopped for sure? Maybe he won't have to worry about it after all.
Thanks everybody for their input by the way. I tried to tell him! LOL.
Old 02-11-2003, 03:02 AM
The Diesel Dude The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
Production has NOT been stopped but it SHOULD BE!!
Old 02-11-2003, 10:24 AM
Tennesseepowerstroke Tennesseepowerstroke is offline
Tennesseepowerstroke is gaining momentum as a positive member of FTE.
Angry New 6.0L PSD Factory Stopwork?
Joe, please tell us why work should be stopped. I have a new F350 4x4 DRW Lariet ordered which should be built next week. I am trading a 2001 F350 to get rid of problems. I will be very dissappointed if the new one starts out with problems. What problems should I look at or for with the new truck before I sign the paperwork or give them a check?
Old 02-11-2003, 10:42 PM
boblamp boblamp is offline
boblamp is starting off with a positive reputation.
Yes Joe, Please elaborate!!!!
Bob
Old 02-12-2003, 04:09 AM
We are currently using 2 factories to build half as many engines as we built by our selves in September. And, about half of those are what we call retrofits or re-entry engines. Ford has demanded that we not send them any more retrofits, so we don't call them retrofits any more, we call them re-entries (they are the same junk as the retrofits). We've got a new engine tracking system which isn't anywhere nearly as good as the old one and the old one wasn't worth a crap! Computers run everything and they are down about half the time. We've got a computerized torque system on the injectors and sometimes the computer doesn't record the torque values. If the torque values aren't in the computer the engine can't be shipped, so we have been retorquing the injectors in repair after the engine is finish assembled, which means the valve covers have to come off (instead of putting a man on the assembly line with a torque wrench before the valve covers go on). We've been doing this for 3 weeks and still the problem has not been solved (we have yet to find an under torqued injector). It is the same thing with the flywheel bolts. They put in a new spur line to send these engines to repair instead of giving the spur line repairman a torque wrench and having him do it. We've got 4200 engines destined for tear down or the retrofit line (we've set up a new line to disassemble these engines, instead of figuring out how to put them together right the first time). In addition to that, we've got another 1000 engines on the floor waiting for major repair. We've installed a "watch dog" program in the computer to prevent these engines from being shipped (which is good) but we are sending retrofit engines to be torn down to a short block for re-entry, to be built back up, and these engines are passing all the tests only to be rejected at the back door by the watch dog because they've already been previously statused as a retrofit which can't be shipped anyway. Some of them have been around the circle 2 or 3 times. Others have failed cold test and instead of repairing the cause of the failure, they were sent for re-entry, built back up and failed cold test for the same problem they had the first time! We are chasing our tails and all those morons in the front office can do is form committies so they can have some more meetings. And to top all that off, they just handed us the worst labor contract in history. We spent 23 weeks on strike in 1979 and 1980 to keep what we had (voluntary overtime) and this contract has manditory overtime. Morale is at an all time low, the people are giving the bare minimum both in hours and effort. They've farmed out test and some repair to non-union shops as well as much of the assembly process. All they want to talk about is diversity and respect for people (they have so much respect for people that they gutted our contract). Those are certainly good things but we run an engine plant. The first thing on the agenda is to build the best damned engines that money can buy. Then, once we have a solid handle on that, we can deal with some programs that aren't directly related to the process of doing what we're in business to do, diversity, for example.
They'd go a long way to repairing the rift if they called back all the laid off workers, brought back our work to be performed in-house and gave us some indication that we are still in the engine business. I am done with them. My boss said I have a bad attitude to which I replied "I am a product of my environment."
Old 02-12-2003, 12:33 PM
JoeBoost's Avatar
JoeBoost JoeBoost is offline
JoeBoost is starting off with a positive reputation.
Go Joe !!
Old 02-12-2003, 12:50 PM
psd tech psd tech is offline
psd tech is starting off with a positive reputation.
Joe, thanks for the " behind the scenes look".:-staun
Old 02-27-2003, 10:28 PM
presidente_coo presidente_coo is offline
presidente_coo is starting off with a positive reputation.
Joe,
http://uaw98.com
I'm told this may take a day or two to show up but it is going to be a great place to share information within the plant.
Spread the word within the plant.
Old 02-27-2003, 11:16 PM
Lectrocuted Lectrocuted is online now
Lectrocuted is starting off with a positive reputation.
Life in the dysfunctional ford family. I feel your pain Joe. Stamped 1000 bad hood skins the other day. Die marks. Definately not the first or last time. The ship is sinking.
Old 02-28-2003, 04:30 PM
diezelonly diezelonly is offline
diezelonly is starting off with a positive reputation.
BOY AM I GLAD I DID'NT ORDER THAT 6.0 DOES'NT SOUND LIKE I WANT MY ENGINE BUILT THERE.
Old 03-01-2003, 10:30 AM
1943GPW 1943GPW is offline
1943GPW is starting off with a positive reputation.
Think about this, if you worked in a plant making something, would you bash it? You might if you were one of the ones laid off! I have a 2003 6.0L and it is running great! I did have the ICP replaced, but that is minor. I hope we are not giving a first hand look at why the foreign manufactures are beating us at our own game. Hay, ford is catching the problems and some don't like it.
Mark
Old 03-01-2003, 11:53 AM
xanthias's Avatar
xanthias xanthias is offline
xanthias is starting off with a positive reputation.
Joe,
Just wanted to thank you bro. I've lurked here longer than I've been registered and I've read plenty of informative posts from you helping other people out. You definitely know your stuff. I'm very gratified to have a 2000 7.3L PSD.
You fellows keep your chins up and turning out that heavy iron! Those of us out here in the world appreciate people who give a damn about what they make.
Old 03-01-2003, 02:12 PM
stormyrider stormyrider is offline
stormyrider is gaining momentum as a positive member of FTE.
I jsut Bought A 7.3 from a local Ford dealer. I asked him about the 6.0 and he told me that they were disappointed by the number of warranty repairs taking place. Stated that so far all were minor defects but was concerned that the number involved could **** off the owners. NO mention of anything serious so far.
Best Diesel Oil? PSD6litre40 6.0L Power Stroke Diesel 79 12-26-2013 06:42 PM
Looking for Tuned 6.0's that have not been studded p8ntballer442 6.0L Power Stroke Diesel 49 04-18-2012 06:18 PM
04 PSD intermittent smoke andrewhans 1999 to 2016 Super Duty 12 01-02-2011 10:39 PM
Ultra-gauge on 2005 Ex 6.0, trouble reading ODBII Misky6.0 6.0L Power Stroke Diesel 9 10-18-2010 08:19 PM
2004 6.0 PSD better than the 2003? KTM Racer 99 Excursion - King of SUVs 5 06-09-2004 08:58 AM
Tags
0l, 2003, 60l, checkout, diesel, engine, f250, f350, factory, ford, fordtruckenthusiast, form, process, psd, sale, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
