Musty A/C Smell
If you live in a humid area-I do-then you will have this problem. I use Lysol because I trust the name brand. The key is getting the product into the vents under the cowl.
Also, roll the windows down, turn the car and a/c on and lower the temp button to 60. Do not put it on recirculate or Auto. Then push the a/c button-shuts off compressor-and turn the fan to high. Turn the key off only enough to shut the engine off, but leave the electronics on. Keep the blower on high and leave it be for as long as you want. You should see some fog on your windshield if it's the right humidity outside. This will dry it out a bit. I would do the Lysol after you have done this.
overlandexpress
1999 to 2016 Super Duty
07-26-2013 10:02 AM
