55F250/460/sanderson headers/right side/clearance
Well, I hate to be the bearer of bad news, but it’s not all bad, its fixable. Your engine is sitting too low. I am doing a 460 in a 51 f1 and have been collecting pictures; here are two from my files. There are more from stillwell (spelling?) and john and others on this site too.
2 ed pic is in a '48. What do you think?
Anyway NONE of these pictures are of my truck, just reference information.
Firist picture two pictures are for Julie, what it would be like in a perfect world (no steering box see above) and with a Toyota box and mashed / smashed headers (not mine).
I'm having a little bit of a clearance issue at the slip-yoke on the trans (C6) where the support bearing for the original 2 piece driveshaft was. If I was to raise it up I would really have problems, but if I have to I have to, nothing has been welded up, just seeing how things fit. Thanks for the pic's
Well, you have the correct ones for your truck, (53- up) BUT the earlier ones do have a different bend. (48-52). I wonder if the ¾ ton frame is taller?
This is Sanderson’s web page (from their much improved web site) showing the 460 headers. The ff462 might work better?
Sanderson Headers for Ford Big Block V8 engine applications.
It could be the angle of the picture bit looks like the right (pass) 56 one sits lower at the rear (outlet) relative to the rear port flange, so maybe the f1 ones sits higher there (it has a kick up in the middle as well) ?
I have a set of f1 ones, maybe you could bring you engine / frame up?
Could you ask Sanderson?
My princess, replace it, how can you replace it? Mustang II IFS do not have a steering box. (It really is a good swap)
But also, I'm noticing that all of these engines you have a sitting about 3 inches higher that the 390 in my truck - which is as high as it could go. That makes quite a bit of difference with exhaust on the drivers side. And the other picture (with the Toyota steerin gbox) also answers the other question.
So, the answer to my question which was really "how did you run the exhaust on the drivers side, and did you modify out or elliminate the stock steeing box" was "yes!"
A couple other things I've noticed is that your 460 motor mount locations are about an inch or two inches farther forward than my 390.
Lastly, the headers you showed are different then the OPs. Yours turn straight back and in toward the engine, and his cant down toward the frame slightly and are straight. different animals. And with these trucks an inch makes a big diff.
I was curious what yo did. Thaks for the pics ad answering my question(s)
IMPRTKLLRZ28
01-08-2011 06:22 PM
F250racer
09-14-2009 06:42 AM
55 dude
04-02-2008 08:00 AM
drydocked
Slide-in / Truck Campers
08-14-2004 12:31 PM
