1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
How to take the dash apart??
Old 06-22-2010, 04:11 PM
HKusp's Avatar
HKusp
HKusp is offline
I am having issues with the auto leveling suspension and I think I have it narrowed down to the module in the dash.I replaced the compressor, both airbags, the fitting by the brake master cylinder with a spiderjr., and the relay for the compressor. I hooked it up to AutoEnginuity and I keep getting a code for the relay, but looking at the trouble shooting procedure from Ford it states that it could also be the module. The relay is brand new and so I am thinking it's the module I have never taken a dash in one of these apart, and I don't want to bust it up obviously, so does anyone have a good write-up of how to take the dash apart on a 2000 Expy?
Old 06-22-2010, 06:00 PM
alloro's Avatar
alloro
alloro is offline
Received 4,178 Likes on 2,421 Posts
Why would you take the dash apart to get at the module? Where do you think it is?
Old 06-22-2010, 06:06 PM
deanjet's Avatar
deanjet
deanjet is offline
I had my dash half way apart once....
I'll never do that again!
There are much better ways to spend an afternoon
Old 06-22-2010, 07:02 PM
alloro's Avatar
alloro
alloro is offline
Aw quit complaining. At least you got a chance to clean the gunk out of the cracks.
Old 06-22-2010, 09:53 PM
HKusp's Avatar
HKusp
HKusp is offline
My friend who is a mechanic that has done a few of these said that it's in the dash right next to the radio. You tell me where it is.
Old 06-23-2010, 10:52 AM
RedHorse1's Avatar
RedHorse1
RedHorse1 is offline
Wow! And I thought the insides of a gopher was nasty looking.
Old 06-23-2010, 02:56 PM
jdecker's Avatar
jdecker
jdecker is offline
The Module is right above the radio, you'll only need to remove the cluster panel to get to it
Old 06-23-2010, 05:04 PM
deanjet's Avatar
deanjet
deanjet is offline
I just did this 2 weeks ago, but my memory is a little fuzzy. This will get you in the right direction....
Grab to vents to the left and right of the radio and pull. I think the module is above that. If so, remove the headlight switch (insert screw driver at bottom), remove screw behind the headlight switch and then pull the drivers vent off. Now pull the little panel between the top of the steering column and below the instrument panel (it snaps in). Now take off the piece of plastic that wraps 3/4 of the way around the instrument panel. Now remove a few more screws to take the large plastic cover off that goes from the left side of the dash to the center just above the radio. Now you should see it.
Old 06-23-2010, 05:43 PM
madsonp's Avatar
madsonp
madsonp is offline
Cluster removal instructions can be found here:
Expedition
shartflhs
Electrical Systems/Wiring
07-12-2013 06:50 PM
S C
04-24-2013 04:39 PM
1995_F150_5.8
Aerostar
07-15-2010 05:25 PM
rschleicher
09-12-2008 09:18 PM
5ass
10-13-2005 11:29 AM
Quick Reply: How to take the dash apart??
