1992 Gas Guzzler
1992 Gas Guzzler
My 1992 Ford Ranger Super Cab is a total gas guzzler. I drive maybe 8 miles a day and I am only getting 10-12 miles per gallon. The car only has a little over 68,000 original miles and I have tried STP Saves Gas and Chevron Fuel Additive and nothing seems to happen. Do any of you guys know of anything I can do to improve my gas mileage?
1992 Gas Guzzler
I drive about 250 miles per week....on average. I've been consistently getting 14.2 - 14.8 miles per gallon. My drive is a city/highway mix. I thought that was TERRIBLE.
Last night, I filled up again and on that tank I got 15.8 miles per gallon. That's a HUGE improvement. Then I started thinking....that tank of fuel came from a Marathon station. I usually go to Chevron.
So the point is, all gas is NOT the same. All other things equal, one station's fuel resulted in a 1.5 mile per gallon increase over another for me. Who knows...maybe if I went to Shell or BP it would be even better (or maybe it would be worse).
Try different brands of fuel....that may help. Also, I'd get that truck serviced at a Ford dealer and have them check the O2 sensors.
1992 Gas Guzzler
Has the truck ever been tuned up, is the air filter clean? The other thing to keep in mind, and this would not explain mileage that bad, but since you take short trips all the time your truck is never warming up and going into closed loop, this is like running with the choke on all the time.
1992 Gas Guzzler
I have a 91 XLT 4.0..........was getting lousy mileage (15 mpg) when I bought it..............found out someone had removed the thermostat so it was running wide open all the time.........never heated up to correct operating temp.
Put one in, now getting about 22 mpg.........
1992 Gas Guzzler
First off, is it a 2.3, 3.0, 4.0? That makes a BIG difference.. but, assuming it's a 2.3..
Could be lots of things. partially clogged cat (not likely, truck would have NO power)
MAF might need cleaning.
Air filter - Checked it lately?
Has this truck ever had a tune up, could be that simple.
Get the codes pulled, might be issues there, O2 Sensor, ect...
All in all, my guess would be that this truck is just in desperate need of basic maintainance. If it were something more severe, such as a bad cyl, you'd be having more symptoms than lousy feul mileage.
Don't forget, driving habits can have a profound impact on economy also, so do what I had to do, get yer foot out of the radiator.
Oh, and do you happen to have a ton of weight in the bed for winter, this will hurt you too..
Of course, if it's a 3.0 or bigger, well, most of that still applies, but, you're never gonna see great mileage, but it could definitely use improving.
1992 Gas Guzzler
Sounds like it's time for a good tune up, and tip off the dealer why you are there so they pull any engine codes. After this is done, do the truck a favor by driving on the highway for about 30 minutes a week; this will warm the engine up and drive off moisture that condenses in it during the week. 8 mile trips on a regular basis are hard miles.
BTW, how do you drive? Do you run around in a lower gear than needed, or to you get into 4th around town (on a 5-SPD)? Winding it out when you don't need to consumes gas, just like flooring it at every stoplight will.
With my 94 4x4 4.0L 5SPD 3.73 axles, I get about 19.7 on the highway, 15 in town. Record milages are 11 (hauling a loaded trailer on freeway) and 24.8 (country roads at 45mph in 5th gear).
1992 Gas Guzzler
