exporer sport trac hard to start
Old 06-21-2010, 11:01 PM
Lewis021475's Avatar
Lewis021475
Lewis021475 is offline
I have a 2003 Explorer sport trac with a 4.0 liter V6 which is very hard to start. The truck only has 69k miles! It usually takes about 3 to 4 trys for the engine to start. Also, In the last 3 months the engine has just shut-off while driving 2 times. The past couple weeks the problem has got worst, any help would be appreciated. Thanks.
Phil
Old 06-22-2010, 12:22 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Connect a fuel gauge to the rail and check the pressure, seems you may not be priming.
Replace the FP relay......
Old 06-22-2010, 07:10 AM
Ed's Avatar
Ed
Ed is offline
Question
Has the "Check Engine" light been tripped?
Old 06-22-2010, 07:45 PM
Lewis021475
no check engine light
there is no engine check light. Also, the hard engine start problem is worst when engine is cold.
Old 06-22-2010, 07:52 PM
Lewis021475
could a bad IAC valve or DPFE sensor cause this problem?
Old 06-22-2010, 10:10 PM
shorod's Avatar
shorod
shorod is online now
Yes, but so could a bunch of other items. If you want to shotgun those two parts, you're welcome to. If they don't fix it you could also shotgun the Engine Coolant Temperature (ECT) sensor, the fuel filter, and the fuel pump.
Cycle the key a few times between Off and Run, pausing in the Off position about 3-5 seconds each time, then try to start the engine. If it fires quickly after the cycling, this would suggest the fuel pressure is low. The fuel pressure gauge suggestion above is a more sure-fire way, but not everyone wants to spend $40 on the gauge. You could start by replacing the fuel filter, but chances are good the fuel pump is weak.
-Rod
Old 06-23-2010, 01:17 AM
Lewis021475
Thank you Rod. I cycled the key 3 or 4 times and on the 5th turn the truck started right up. It does seem the problem is in the fuel delivery system. I'll change the filter first...I'm sure it's due any ways. If the problem is still there I'll check out the fuel pump. Do you think it could be the fuel pump relay? Well, again thank you very much.
Old 06-23-2010, 06:49 AM
shorod's Avatar
shorod
I doubt the fuel pump relay is the issue. You can check for voltage on the pump side of the fuel pump inertia cutoff switch. If you always have battery voltage or close to it at the switch but you still don't get quick starts unless you cycle the key a few times, that would pretty much rule out the relay or a bad connection, unless the bad connection is at the fuel pump in which case you need to drop the tank anyway.
-Rod
RMcCargar
01-13-2022 10:21 AM
brokeasajoke
07-11-2019 05:22 AM
1998Ranger25L153CID
05-04-2016 10:22 PM
jswford
04-21-2015 04:46 PM
chris_tina1608
03-30-2013 09:34 AM
Quick Reply: exporer sport trac hard to start
