1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
No Start Issue - PRNDL error no backup aid
Old 08-29-2014, 11:47 AM
mewesguitars's Avatar
mewesguitars
mewesguitars is offline
the only lights on the dash that work are turn signals. headlights, interior lights all work.
Old 08-29-2014, 04:00 PM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
Who flashed the new ECM for you, the dealer?
Old 08-31-2014, 10:11 AM
mewesguitars
flashing pcm
found a guy on Ebay that flashes PCM's. He had 100% feedback so I trusted he knew what he was doing.
Old 08-31-2014, 11:33 AM
alloro's Avatar
alloro
alloro is offline
Mistakes happen. Have you contacted him to say that there could be a problem with the flash job he did?
Old 03-28-2016, 03:32 PM
mikeavery's Avatar
mikeavery
mikeavery is offline
Solution
The problem usually lies within the fuse box. I repair this issue along with the other common issues of no start, stalling and fuel pump no power. If you need me to repair yours contact me at: eclipsepro2000@yahoo.com
Old 03-28-2016, 07:19 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Yeah, that was almost two years ago....
Quit spamming the forum!
Old 06-22-2016, 03:28 PM
mikeavery's Avatar
mikeavery
It's not spamming if it answers the problems that people are looking for. Maybe you should post a better answer to people that are looking to fix their vehicle.
Old 07-10-2016, 10:46 PM
Bradlbrea's Avatar
Bradlbrea
Bradlbrea is offline
Having this issue, please help me!!
Old 03-26-2019, 09:49 AM
Numatrix7's Avatar
Numatrix7
Numatrix7 is offline
Possible Fix, It Helped Me
So this Video helped me fix my truck, My truck started right up, no more issues
Originally Posted by 03BLKEB
Truck is a 2003 Expedition Eddie Bauer, 5.4 4x4
Wife driving truck and apparently it went bang and then was loud like an exhaust issue.
- tracked that to the #4 plug backing out and the COP breaking.
However, the truck has in the message display "PRNDL error no back up aid" and the truck will not start. Hooked up two different code readers and neither will read at all, so I am guessing that the PCM is not being found?
- Checked the fuel cut off switch
- Checked Starter motor (Jumper) and it turns under battery power just fine
- Checked all fuses, they are fine
- Relays appear to be fine - nothing blackened or melted
- Checked backup lights when in reverse and they work
- Tried starting in all P,R,N,D,L positions with no luck
- Replaced the Auto Trans Gear Position Sensor, thinking it may be bad, no change
Any ideas, I am quickly running out of other things to check and going to the dealer is sadly becoming a realistic solution!!!!
My only other thought is to remove the Fuse panel and see about any other relays on the back (the theoretical R 301, 302, 303)
Please help!
Anyone with an idea??? Please, otherwise this is likely to go to the dealer this afternoon.
bagman7
1999 to 2016 Super Duty
04-15-2021 02:04 PM
hharris8
208
02-15-2017 10:56 AM
Dwilt50
01-20-2017 05:43 PM
tjdad62
18
01-02-2017 05:51 PM
Jesser02EX
09-16-2016 09:31 AM
Quick Reply: No Start Issue - PRNDL error no backup aid
