head light-high beam relay? - Ford Truck Enthusiasts Forums
Old 02-06-2003, 10:22 PM
mgorman mgorman is offline
mgorman is starting off with a positive reputation.
Question - I have a 2000 f150.
I have parking lights, fog lights but no head light or high beam however the high beam light comes on when ever either the high or low are supposed to be on. I found a relay for the parking lights and one for the fog lamps but nothing for the high beam or low beam. All fuses look good.
Is there a relay? Or am I missing something and just standning in the cold?
mgorman
Old 02-08-2003, 05:25 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
Dear cant see the light, I could not pass it up shame on me. Just a quick question. Do your emergancy fourway flashers work? Do your turnsignals work on the outside of the truck, as well as on the dash?
Old 02-08-2003, 09:10 PM
Every light but the lows and highs worked.
I ended up getting the thing fixed. After I tested every thing I could find I ended up buying a new multifunction switch like what was posted elsewhere as the culprit. Since my dash high beam indicator was always on, I figured that yes, that could be the problem in the high-low switch. I put a new one in $80 later and they still didn't work.
Being totaly Peeved I started back at the head lights and pulled the plug off and when I did the light flashed. I put it back on and nothing. Repeated the process and the same. Upon further inspection of the socket I found it to be melted from either heat or a moisture induced short. The plug was warpped and the negative contact was not touching the prong on the lamp. I bent the prong forward and replaced the socket back on the light and both lights came back on. I also found out that the negative contact was far enough away that my multi tester propes couldn't reach it and that is why I wasn't getting a reading. I should have grounded to the frame or battery also when I tested it to make sure the neg. even worked.
I have never had a truck where one light goes out, they all do. The engineer must have worked for those Christmas light companies from years past.
Anyone without flash to pass want to upgrade, Got a slightly used multiswitch in search of a good home.
mgorman
Old 02-08-2003, 10:21 PM
Glad you found it. those mfs, Thats multi function switches seem to be a problem on later model trucks. Thats why i was asking about the turnsignal issue, it seems to start there.
Old 02-09-2003, 08:42 AM
the local ford dealer wanted $90 to diagnos it. Either way I did better because they would have charged me for more parts any how and my truck wasn't held up in maintenance. Unfortunately, If I had been more patient and double checked everything, I'd still have my $
Thanks
Old 02-12-2003, 07:51 PM
More info for future readers:
From Scully
You can try Napa for a replacement headlight socket.
I upgraded the one on my Kaw, from the crap stock one, just to run a SilverStar bulb ( that is how bad the stock one was ).
Although the Kaw has an H4 bulb, you can take it in there, and tell them at the counter you need a socket for a 9007 type bulb.
Once you get it, you can butt connector splice it together, ir solder heat shrink it back to the stock harness, and be on your way alot faster then going to the dealer for the same stuff.
Also I don't know if Ford would sell the socket, or the entire harness back to the first connector from the head light socket.
either way should get you on your way, I'd try Napa and save a few bills for a better part, just a thought.
Can you post this back to the thread, so others can see it. Just helps to have more info, rather then less.
Steve
Mod to keep fog lights on with Hi-Beams? troverman 1999 to 2016 Super Duty 15 11-07-2013 01:45 PM
Wiring fog lights snowdog79 Electrical Systems/Wiring 2 03-19-2011 01:26 AM
Fog lights / High beams not working, help? blcfacets 1999 to 2016 Super Duty 0 08-07-2010 06:47 PM
High beam and fog light mod? aquaman 6.4L Power Stroke Diesel 4 11-11-2009 01:57 AM
Fog Lights dont work when High beams on? easttxtycoon Escape & Escape Hybrid 7 01-18-2005 07:59 PM
Tags
1997, 2003, 97, beam, f150, ford, fuse, hid, high, light, location, low, melted, relay, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
