dirty oil ? - Ford Truck Enthusiasts Forums
dirty oil ?
Old 06-21-2010, 04:53 PM
firebug firebug is offline
firebug is starting off with a positive reputation.
dirty oil ?
I am having trouble with my HPOP and the ICP has oil in it. I was told that both need to be replaced. The question I have is that a dealership tech told me that my problem may just be from dirty oil. I normally change my oil at 5000-7000 miles, I was wondering how many miles and how dirty can the oil get so that it will make the truck not run ?
Old 06-21-2010, 06:56 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Dirty oil can cause problems, what are your symptoms? Changing it is easy and certainly won't hurt to do it early. At least you'll know if it's your problem.
Oil in the ICP = New ICP unless you spilled it in there.
The HPOP is the last thing to check/replace until you get the other items out of the way.
Old 06-21-2010, 07:00 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Dirty oil can definately make it run badly. Or if you use certain oil additives it can make it foam up and not run right.
why is my oil so dirty? wetbiker 6.0L Power Stroke Diesel 29 08-21-2015 01:51 PM
dirty transmission oil adamkat22 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-09-2015 10:20 PM
How to remove dirt from 7.3 fuel tank? Sous 1999 - 2003 7.3L Power Stroke Diesel 9 03-02-2015 06:33 PM
Air Filter Change mpwbw General Automotive Discussion 13 06-03-2014 02:48 AM
2005 6.0 coolant disappearing hunter3014 1999 to 2016 Super Duty 0 05-05-2014 01:19 AM
Tags
2000, 54l, 73, diesel, dirty, effects, engine, engines, f250, ford, fuel, oil, powerstroke, problem, problems, symptoms, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
