Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-21-2010, 12:41 PM
Kws3sc Kws3sc is offline
Garage is empty, add now
Kws3sc is starting off with a positive reputation.
Speed o meter, Tach o meter, Trans mission
My 97 Expedition (189K)recently started having issues. The tach will be reading fine then drop to zero, then work fine again. Sometimes the speedometer will bounce up and down within 5 mph. Now, the OD indicator will start blinking and the transmission will start shifting hard and take longer to shift through the gears. If I turn the ignition off and start it back, everything resets and seems to work fine for a while.
All of these issues have started over the last month. The tach problem happens at any speed, the speedometer happens with no predictible frequency and the transmission issue seems to only happens after 15 plus miles but sometimes it doesnt do it after 100 miles.
Somedays and on short drives, there doesnt seem to be anything wrong at all.
Any help would be greatly appreciated. Thanks
  #2 (permalink)
Old 06-21-2010, 01:04 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
This is the 2007 and up forum.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 06-21-2010, 01:06 PM
Thanks you.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
