Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 06-21-2010, 11:21 AM
loudfords's Avatar
loudfords loudfords is offline
1979 Ford F-150
loudfords has a good reputation on FTE.loudfords has a good reputation on FTE.
Question Summer truck projects
Seeing as today is the first day of summer, does anyone have any summer truck projects planned? I just replaced the starter solenoid in mine, and one of the door latch pins, and put a CD player in, only plan for me is to replace the pin on the other side now.
__________________
Chad - loudfords - Ontario Chapter Leader
Click HERE to join the Ontario Chapter
1979 F150 351W
2003 Explorer XLT
  #2 (permalink)
Old 06-22-2010, 10:47 AM
98 nascartruck's Avatar
98 nascartruck 98 nascartruck is offline
1998 Ford F-150
98 nascartruck is starting off with a positive reputation.
Just minor stuff like repainting the NASCAR style rear spoiler and MAYBE a new head stereo unit!!!!!
__________________
Gordon
Owner of 1998 NASCAR special edition F-150 truck
(Celebrates the 50th anniversary of NASCAR and F-150)
  #3 (permalink)
Old 06-22-2010, 03:41 PM
77460ford's Avatar
77460ford 77460ford is offline
Garage is empty, add now
77460ford is gaining momentum as a positive member of FTE.77460ford is gaining momentum as a positive member of FTE.
Got rid of the electronic fan controller for the Mark VIII and replaced with twin relays for low and high speed. Much better temperature control.
__________________
'77 F150 4X4 472/C6/4:11's/35's
2 - 50lb. Nitrous bottles
  #4 (permalink)
Old 06-23-2010, 09:23 PM
truckfarmingcanuck's Avatar
truckfarmingcanuck truckfarmingcanuck is offline
truckfarmingcanuck is starting off with a positive reputation.
I fixed the busted power steering line on the Mustang which led to ripping the rack and pinion out ....and then the tie rods....then the ball joints .....struts are needed but they went back in for now. Lots of grease and cursing but the kids are in the back and we've been cruising happily with the top down for 2 weeks now. So far 400 kms and no leaks or roll overs so I think everything is back on order.
Had the old truck out once will get at it after some holidays
TFC
__________________
Jeff's Fleet
1974 F100 Ranger XLT "Tennessee", 1977 F150 Supercab "Stretch", 1979 F100 "Copper", 1981 F150 Stepside "Ethyl", 2001 F150 4X4 7700 Series "The Big Truck", 1986 Mustang Convertible and a 1955 F100 yet to me named.
  #5 (permalink)
Old 07-08-2010, 08:14 PM
fp_5's Avatar
fp_5 fp_5 is offline
fp_5 is starting off with a positive reputation.
more work on my friends '97 F150 POS!
Got my side tank resealed and put back in finally. Ordered a sending unit from JBG and it didn't fit, wasn't going to send it back so I modified it to work. Very interesting fuel gauge readings from that tank now! oh well it holds gas and I need a lot of gas.
Also finally got my 300 I6 block and rotating assembly back from the shop, new pistons, mild cam, .030 over. Scored a Clifford intake on eBay and some powder coated headers on kijiji., still hunting for a carb and I have to get the np435 checked over. No luck on finding a ZF5 yet.
Started died on the 460 but that was easy enough.
Now to start on the Camper,....haven't done much. Washed the curtains and order new foam cushions. I took out the toilet too, nasty business but I have to clean it up and fix a leak. Going on a camping trip in week so I'll find out what else need fixin.
frank
__________________
'76 F100
'64 Falcon
'47 & '48 Ford Fordor Super Deluxe
'77 F250 Super Cab
" I thought I was wrong once but,...I was mistaken"
  #6 (permalink)
Old 07-08-2010, 09:31 PM
Red Ford Truck's Avatar
Red Ford Truck Red Ford Truck is offline
Red Ford Truck is gaining momentum as a positive member of FTE.
How'd you like dealing with JBG?
frank
I find the prices are great but the delivery can be a little on the slow side and Jeff can be a little grumpy
__________________
Red Ford Truck
  #7 (permalink)
Old 07-18-2010, 06:42 PM
falconqueenD's Avatar
falconqueenD falconqueenD is offline
1977 Ford F-150
falconqueenD is gaining momentum as a positive member of FTE.falconqueenD is gaining momentum as a positive member of FTE.
Red face $$$$$$$$$$$$$$$
Upper and lower ball joints. All new brake lines flex and steel. Rewired firewall to tailights. Newsteering shaft,front axle u-joints, u-joints in front shaft from the transfer case. Speaking of transfer case I replaced that to.
But I have to give credit to the '70s Ford GURU for doing all the work and we've only just begun.
Still waiting for my rear shocks to arrive that will complete all the front ones waiting to go on.
HELL IT ALMOST SEEMS I SHOULD HAVE DONE A FRAME OFF.
THIS WINTER COULD BE INTERSTING, ENGINE COMING OUT!!!!!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
