F250 front fuel tank problem??? - Ford Truck Enthusiasts Forums
Old 06-21-2010, 12:04 AM
38-72 38-72 is offline
38-72 is starting off with a positive reputation.
After stopping to fuel up, I started up the road and my truck sputtered a bit and died. I was running on the front tank when this happened. I tried to restart the truck, but it would not. I flipped the switch to the back tank and it start up. It runs just fine on the back tank, but will not run on the front tank at all. Never had any problem like this before. Just a wild a$$ guess, but I'm thinking the fuel pump died. Or, could it be someting else?
What say you?
Old 06-21-2010, 12:09 AM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
Truck info!
Old 06-21-2010, 12:24 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
Quote:
What say you?
Sounds like it. It happens that way a lot of times. I was on my way to the airport one day, stopped in at my office for something for like 5 min, got beck in my car and that was that... just cranked and cranked. Pump died.
Do you hear the pump run when switched to the front tank and first turn the key on?
Old 06-21-2010, 12:35 AM
topdogcustoms topdogcustoms is offline
topdogcustoms is starting off with a positive reputation.
mine does the same thing but only when its hot outside
Old 06-21-2010, 08:32 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Yes it would be the pump in the tank or the selector switch on the dash that is bad on your 1996 F250.
Old 06-30-2010, 01:27 AM
up date on fuel pump issue
Thanks for the replys!! The truck is a 1997. I haven't time to work on it much. The pump didn't whine. However, today I got a chance to drive the truck and I flipped the switch to the forward tank and guess what, it works. Hmm, what the heck is going on?
Old 06-30-2010, 10:56 AM
Tegetus's Avatar
Tegetus Tegetus is offline
Tegetus is starting off with a positive reputation.
sounds like a bad selector switch
Old 06-30-2010, 11:02 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
change you selector switch, run some heat and fuel injector cleaner through it to make sure you don't have condensation in the tank... enough moisture could cause the engine to die. the heat will clean that out and the injector cleaner will clean the ports on your injectors... just to make sure you are all good that way...
Old 06-30-2010, 12:20 PM
johndeerestx30 johndeerestx30 is offline
johndeerestx30 is starting off with a positive reputation.
I wouldnt rule out the fuel pump just yet. It could be on its way and driving around could have just knocked it enough to get it going a few times. I work road service for AAA and often can get a fuel pump running again by tapping on the tank, works the same way as tapping on a starter.
Just my 2 pennies
Old 07-06-2010, 12:49 AM
DriftKing92 DriftKing92 is offline
DriftKing92 is starting off with a positive reputation.
So im a nebbie and only know fairly basic vehicle knowledge....but i have a 1995 F-150 which seems to have this similar problem..... it has been a problem for the past 2 years or so but the front tank would always have a hard time starting and when it would start it might die a few mins later. If the start up was okay then once you started going down the road the vehicle would lurch back and forth down the road and sometimes flooring the gas pedal would do nothing different then barely applying pressure.... this is only on the front tank...the back tank runs like a brand new vehicle and is completely smooth...oh and also it is a standard and that problem happened in all gears but occured the most between 1-3 gears....i have already tried fuel injector cleaners and have found know real improvement.........PLEASE HELP!!!
Old 07-06-2010, 06:02 AM
subford's Avatar
DriftKing92,
Same answer as in post #5 above. The pump in question would be the front pump.
Old 07-06-2010, 05:42 PM
Okay but just in case could it be anything else besides the selector switch or the fuel pump? and how do i go about repairing the fuel pump if its the problem.?can it be a do it yourself fix or do i need a shop to fix it? and how would i acces the front fuel pump?..... Thanks
Old 07-06-2010, 05:56 PM
subford's Avatar
You can either take the bed off, the way I like to do it.
Or you can drop the fuel tank.
You will need two fuel line disconnect tools to get the fuel lines off the FDM.
I like to spray WD-40 into the fuel connector and twist it to break the "O" ring free before I put the tool in the connector.
After the two lines are off remove the large ring, unplug the FDM from the frame plug and lift it out.
Then replace the whole FDM or cut the wires and remove the part that has the fuel pump in it. Push on a new one on and crimp the wire.
Old 07-09-2010, 12:48 AM
ratrod-mike's Avatar
ratrod-mike ratrod-mike is offline
ratrod-mike is starting off with a positive reputation.
I seem to having the same problem - fuel pump
I seem to having the same problem on my 1996 Ford F250. Ran fine and now will not start. I turn the key on, but can't hear the front fuel pump running. I switch to the back tank and still no fuel pump running. Hard to believe both pumps went out at the same time. I checked the fuse box under the dash and under the hood...no fuses blow...I think. Any idea which fuse goes to the fuel pumps? Any suggestions on what to try next?
Old 07-09-2010, 06:38 AM
subford's Avatar
ratrod-mike,
Is your truck OBD-1 or OBD-2?
Do you have spark?
Have you checked to see if you have any codes? If not do so as they may tell what is wrong.
Does any of the relays in the fuse box under the hood click when you turn on the key?
Fuse #20 is the Fuel Pump Fuse:
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
86 F250 Fuel Guage Problems tony_corbin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-05-2014 10:35 PM
ANOTHER FUEL PROBLEM please help fordsrawesome 1987 - 1996 F150 & Larger F-Series Trucks 2 12-10-2011 09:00 AM
dual fuel tank problem biggyman50 1987 - 1996 F150 & Larger F-Series Trucks 10 10-12-2010 10:44 PM
1990 Front Fuel tank problem old blue 90 1987 - 1996 F150 & Larger F-Series Trucks 5 07-04-2009 04:19 PM
Tags
2003, 250, 91, 96, f250, ford, front, fuel, gas, inline, problem, problems, tank, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
