Mint 1995 350 understeer? loose feeling steering - Ford Truck Enthusiasts Forums
Old 06-20-2010, 11:47 PM
mint350 mint350 is offline
mint350 is starting off with a positive reputation.
So i just bought a mint 95 350 7.5. Im noticing that the steering seems loose. Like im always turning the wheel to keep it straight. Also feels like there might be some tire wobble. Anyway, would appreciate some help diagnosing the problem.
Old 06-21-2010, 12:00 AM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
I'm going to say Tie rod bushings.
Old 06-21-2010, 12:18 AM
Yeah, thats what im thinking! Thanks for the reply.
Old 06-21-2010, 01:18 AM
skucera's Avatar
skucera skucera is offline
skucera is starting off with a positive reputation.
Take it to an alignment shop and have them examine it. Most shops will do a free estimate in hopes of getting the job. It might be worn tie rod ends, a loose Pitman arm on the steering box, suspension bushings, or even low tire pressure. If the problem is free play in the steering wheel, the steering box may need to be adjusted. Recirculating ball steering boxes are designed to be adjusted to compensate for wear. The procedure is in the manual, but don't overdue it or you can cause binding and accelerated wear in the steering box.
Scott
Old 06-21-2010, 09:10 AM
DAT2109 DAT2109 is offline
DAT2109 is starting off with a positive reputation.
Quote:
Scott
Make sure to at least tip the technician $20 if you do this. They make so little doing a full alignment job, if you arn't going to have them do the work it really puts a dent in their paycheck to only do free inspections. Plus if you come back afterwards to get the new parts lined up they will remember you and treat you better.
Old 06-21-2010, 09:32 AM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
All of what they said plus I have seen the slip joint in the stearing shaft get loose on these also the splined coupler that connects to the box, take a look.
Old 06-21-2010, 12:48 PM
ymeski56's Avatar
Der Postmeister
Quote:
Never hurts to grease the skids if the guy is knowledgeable & honest. The problem with the front end (especially Ford's twin I beam) is, it's hard to find a shop that won't try to do a "dog & pony" show, w/ a big price tag at the end!
If you stand in front of your truck, have someone slowly change directions w/ the steering wheel. If you notice a lag time between when one or the other tire changes direction, tie rod bushings. They will also start raising hell w/ the rest of your components.
This doesn't rule out other components, but from my experience with 8-10 high milage Ford trucks, concerning tie rod bushings, it's not a question of if, just when. Personally, I think it's the most under engineered part of the truck.
Old 06-22-2010, 12:58 AM
skucera's Avatar
I couldn't have put this any better myself.
Scott
Old 06-22-2010, 06:24 AM
thomer thomer is offline
thomer is starting off with a positive reputation.
I have a 96 f-250 and experienced the same problems you are speaking of! My truck ended up having 2 of 3 axle u-joints going bad!
Old 06-23-2010, 07:50 PM
steering
Ok now im starting to feel some knocking when i back out of a drive way and turn the wheel. Its on the drivers side. I can feel it thru the floor board.
Thanks
Old 06-23-2010, 08:31 PM
ymeski56's Avatar
Der Postmeister
Quote:
Thanks
That would be your girlfriend! Her skirt's caught in the door and she would like you to stop for a moment!
Old 06-23-2010, 09:02 PM
clanking while steering
Well done sir!
Old 06-23-2010, 11:48 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Thanks
U joints in the axle half shafts...they need replaced.
Is the 6.0 right for me? motomax55 6.0L Power Stroke Diesel 30 09-08-2014 11:15 PM
Cruise control - High Idle set? 94F350IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 01-25-2010 11:01 PM
Tie rod and drag link replacement tbear Brakes, Steering, Suspension, Tires, & Wheels 0 10-13-2008 07:39 PM
97 Ford F350 leophard189 1994.5 - 1997 7.3L Power Stroke Diesel 8 09-03-2006 11:56 AM
90 Ford Bronco, Need reliability info! caddywhompus 1978 - 1996 Big Bronco 10 06-19-2003 08:08 PM
Tags
1995, 199597, 97, box, end, f250, f350, feeling, ford, front, loose, mint, sale, series, steering, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
