Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 06-20-2010, 10:43 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
Garage is empty, add now
strokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to all
Location of TAD, TAB, and EVR on 1st gen lightning?
Hey guys. more questions for the 1st gen lightning guys. On my F-150 i have too much stuff back around the rear driver side valve cover now to be able to mount my coil, TAB, TAD, and EVR to it. So now i want to change it over to how the lightnings mount. i know the lightning coils mount up on the front of the engine, but where does the bracket bolt to??? Also where can i get a lightning coil bracket? i have searched all over the place and can't find a bracket for it. Does the solenoids mount with the coil like the regular F-150's or somewhere else? If they mount somewhere else does anyone know where to get that bracket as well??? thanks guys.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC 2wd PSD ZF5- 500+hp daily driver.
1994 F-150 4x4 408w- 10.5:1, TFS heads, custom cam, etc.
  #2 (permalink)
Old 06-21-2010, 08:33 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Honestly, this is the last place I'd recommend for a coil relocation. On the fender well, behind the battery would be a good spot. You just need to extend the primary wires and use a long coil wire.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 06-21-2010, 10:29 PM
Quote:
I will take your word for it. Do you mind if i ask why it's a bad spot? i assume it's a PITA to work on in that spot.
Also do the lightnings use a vacuum tree of some sort since they have the GT40 intakes? i have a typhoon on my F-150 now and trying to figure in my head how i'm going to run the vacuum lines. i thought i'd get a tree from a diesel b/c they have a tree on the driver side fender well with like 6 ports on it i think. No idea on the TAB, TAD, and EVR??? i guess i can move those to the fender as well with the coil
__________________
  #4 (permalink)
Old 06-22-2010, 10:22 PM
Blurry94's Avatar
1994 Ford Lightning
The coil, on a GEN 1, is mounted to a bracket that attaches to the water pump. It puts the coil downstream of the radiator and it tends to soak up a good bit of heat.
The GEN 1's utilize a vacuum tree that is mounted on the back side of the upper intake; on the flange that the EGR spacer attaches to, which is where the rest of the components are located as well.
__________________
Matt C.
  #5 (permalink)
Old 06-23-2010, 07:29 AM
Ahhh... i guess mine will be going to the fender well and so will the TAD, TAB, EVR, and vacuum tree. thanks for the help!
__________________
Tags
1994, 95, bracket, coil, f150, fender, ford, gen, lightning, logos, needed, tab, tad, tree, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
